Old 9th July 2009, 08:33 PM   #21
Originally posted by akis
You have connected both Vcc+ pins on the chip, is that needed? I am gemnuinly curious because I have not bothered to connect one on mine, I could not fit in a thick trace so I thought why bother.
Even if they are internally connected, they should both be connected unless otherwise specified. A possible reasons for two pins could be current sharing. Or it could have to do with the temperature distribution in the package. If there was no reason, the designer would have saved the work and the additional connection.
Originally posted by Razor_x
Is this going to affect the sound
Could be. The coil will inductively couple its signals into neighboring traces and components and vice versa.
Will different lengths of power rails affect working of amplifier? How would you solve this on my PCB?
In theory, yes. In practice you might not notice the difference.
Have a look at National's reference designs for LM1876, 4765, 4766 (homepage) or 4780 (datasheet). You could copy the way it is done there. You will find that the 100 nF decoupling capacitors are very near to the IC's power supply pins, and that the supply capacitors are physically located in a certain pattern. The bigger the capacity, the further away from the IC they are.
Look also, how the grounding is done there and how the designer tried to avoid running certain traces in parallel and how traces cross each other at right angles, where possible.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th July 2009, 08:44 PM   #22
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Why not just use an LM4780 chip? It offers 2 3886 channels on a single chip, and should allow for a more compact stereo layout.
Brian
Old 10th July 2009, 02:09 AM   #23
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Brian
i think he is determined with single layer pcb.lm4780's pins is too compact to deal with.maybe lm4766?lm4766 is a dual 40w power chip.
Zang
Old 10th July 2009, 02:16 PM   #24
Razor_x is offline Razor_x  Croatia
Send a message via MSN to Razor_x
I have already got two LM3886TF and I can use only single layer pcb.
To sum up, generally speaking, is this pcb (with small changes, not important) going to be OK? Will there be any hum or noise in your opinion?
Old 10th July 2009, 02:24 PM   #25
akis is offline akis  United Kingdom
All things could go wrong.
http://www.diyaudio.com/forums/showt...84#post1876884
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 07:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 06:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 12:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.08231 seconds (76.61% PHP - 23.39% MySQL) with 11 queries
