My LM3886 PCB
My LM3886 PCB
Old 7th July 2009, 10:50 PM   #1
Razor_x is offline Razor_x  Croatia
Send a message via MSN to Razor_x
Default My LM3886 PCB
I am designing my own PCB schematic for two LM3886 amplifiers on the same board (stereo). This is what I have made:
I have transformer with two center trapped secondaries that I 'm going to use with this amp.
Can you please check my design for any mistakes? Every advice is welcome before it is to late.
Thank you in advance!
RazoR
Old 7th July 2009, 11:29 PM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
I don't understand the 1 ohm resistor after the rectification . Is it the correct value ?
Some may use it after the first smoothing capacitor but followed by another with the same value . I would keep the power rails symmetric and shorter , in this case you should cut the input traces and do some wiring over the PCB . Then ,each channel has its own star ground ,but you should think it globally , so instead of a star you could have drawn a circle or a square , which is the same for the purpose .
After : you could have it done in half the space you used , since all the "job" is done by the chip...
Old 8th July 2009, 03:21 PM   #3
Yes, I thought of putting 1 ohm resistors after first smoothing capacitor, but now I am going to put jumper at its place.
I forgot to draw two input signal input capacitors (3,3u).
So is the grounding correct?
Old 8th July 2009, 07:44 PM   #4
pacificblue is offline pacificblue  Germany
The rectifier on the drawing looks like a KBU8 or similar. The datasheet specifies a protective resistor of 0,8 Ohm with 5000 F and 1,6 Ohm with 2500 F. 1 Ohm with 3300 F seems to be a good enough approximation.
Nobody in the forum seems to use those resistors and nobody seems to have problems without them. That does not mean they should not be used. Manufacturers usually don't specify those things for fun, because customers hate any unnecessary additional cost and losses.
The alternative would be a high current bridge rectifier, like the KBPC in 35 A version or so. They can deal with big capacitors without protective resistors.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 8th July 2009, 07:57 PM   #5
So the resistor is there only for the in rush current at power up , even to prevent a low wattage transformer to melt ?!?
The grounding for me is wrong . It does symbolize what a star ground is (for a channel) , but it looks like a spider web in this case : Don't be afraid , it probably works , sure it will without any problems .Just the concept ,right ?
Old 8th July 2009, 08:22 PM   #6
No, it is there to protect the rectifier by limiting the charging current to the capacitors.
Old 8th July 2009, 08:40 PM   #7
akis is offline akis  United Kingdom
Amazingly I am also making a guitar amp for my son (who already has two guitar amps), using the same chip as the post amp.
Here is my schematic and board layout (I will have to post multiple times). I only do it in the evenings after work so please feel free to shout if you spot errors.
Old 8th July 2009, 08:46 PM   #8
By the way, I have not decided on the values of the feedback circuit just yet, so it is currently random on the schematic (x20 I think).
Anyway, this is the PCB (sorry it is too small to see clearly perhaps) ?
Old 8th July 2009, 08:50 PM   #9
I thought the supply should be able to deliver full power immediately , as cables for speakers should be near zero resistance . maybe it is not the case for LM38xx series ,as they don't exhibit superb slew rates ;if people can detect difference in cables (transmission) , surely 1 ohm at the generator could cause fatigue at power peaks.
It is ok to over dimension the power of the rectifiers and of capacitors in the supply
BTW I don't understand the huge transformers often used for chip amps.Are they pretended to be used lately in case of chip failure for a discrete design?!?!?!
Old 8th July 2009, 08:52 PM   #10
And this is the separate PSU board. It will sit very close to the board, inches away, but separate nevertheless.
My LM3886 PCBHide this!Advertise here!
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 08:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 07:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 01:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Copyright ©1999-2017 diyAudio
