Old 6th July 2009, 06:11 AM   #1
Zoodle is offline Zoodle  Australia
Default STK4141 on batteries
I have a STK4141-II based receiver that I've been tweaking. It's now a power-amp only. Thanks to advice from this forum (thanks!), I recently uprated the smoothing caps (tripled). Wow!
The amp seems to run from 26-0-26 (the app note for the chip recommends up to 32v). I can get old 12v Lead Acid batts for free. So, I was thinking about four batts in two banks: '+'24V--0--'-'24V.
Then I read about offset problems that might occur if the battery banks are not equally charged, or if one bank depletes more rapidly than the other.
Can anyone comment on this?
Old 6th July 2009, 07:33 AM   #2
Mooly's Avatar
Safety first ! If using lead acid batteries ensure they are fused at the terminals. Never underestimate the amount of current that can flow.
Any normal DC coupled configuration of opamp (the STK's are really just power opamps) is unaffected by unequal rails. The output zero point is determined by the ground referenced inputs and internal offset imbalances... nothing to do with the rails.
Old 6th July 2009, 11:59 AM   #3
sakis is offline sakis  Greece
sakis's Avatar
Default suposing
that this will work from batery ....really what is the point ???
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th July 2009, 12:23 PM   #4
analog_sa's Avatar
Default Re: suposing
Quite obviously to experiment with "battery" sound. Did you expect it to be for a portable disco?
Old 6th July 2009, 12:25 PM   #5
analog_sa's Avatar
Default Re: STK4141 on batteries
Not sure if you can draw any conclusions based on old batteries. Quite often they don't sound nearly as good as new ones.
Old 6th July 2009, 12:57 PM   #6
sakis's Avatar
Default may be it has a point
on a decent amplifier ...presuming that power supply is as clean as possible this will have some effect on sound
but in an stk amplifier is there a point realy ???? i would bother to play with a better amplifier but nothing like that
Old 7th July 2009, 03:00 AM   #7
Mooly,
Thanks. Yes, fuses at the batt end! Good reminder.
Analog_sa,
I'd read that different batteries have different noise levels, so it makes sense that old will sound different to new. Fortunately, I have a good choice of batts, some better than others.
Sakis,
You might be right, but the STK (which I found on the street) is the best I can afford at the moment. Besides, I enjoy turning 'junk' into something useful.
Old 7th July 2009, 07:10 AM   #8
sakis's Avatar
Mooly,
Analog_sa,
Sakis,
..... hmmm yes you must be right stk is junk !!! but then the good thing is that you might get something out of it by learning the benefits of the batery issue or by simpli working arround in this circuit ....
carry on .... let us know about ""before and after"""
keep an eye on the "dynamics" play demanding things to be able to see the diference
try to notice the briliance of the high
let us know
Old 7th July 2009, 07:46 AM   #9
analog_sa's Avatar
Default Re: may be it has a point
You are probably right, the STKs i've heard did not sound too good. There is at least one diyaudio member who really liked some of the STKs though and he seemed to know what he was talking about
http://www.diyaudio.com/forums/showt...9669#post29669
Old 9th July 2009, 04:18 AM   #10
I contacted the author of the post mentioned above: he seems to think that an imbalance between the '+' and '-' battery banks will cause trouble with this chip. So, that's one opinion 'for' and one opinion 'against.'
Anyone else have experience using a twin rail chip with a battery supply?
How to run an AC mic pre from batteries oaks Power Supplies 6 17th October 2009 06:02 AM
Bypassing Tone Controls (STK4141-II) Zoodle Chip Amps 4 29th June 2009 07:07 AM
STK4141 is not always STK4141 matti6 Parts 6 17th March 2007 07:38 AM
SLA batteries for UcD amp PS Paul Ebert Class D 0 16th November 2004 04:53 PM
3 pin li-ion batteries Holger Barske Parts 1 12th May 2004 07:54 PM
Page generated in 0.09950 seconds (82.98% PHP - 17.02% MySQL) with 10 queries
