| Chip Amps Amplifiers based on integrated circuits |
Hi Folks , I just thought I would share a simple Single sided small LM3886 PCB with you .....
The version is pretty much the Datasheet implementation with no special features or components... It measures 2 in x 1.3 in and has a single Jumper and is easy to etch at home .... I just built one and it works perfectly and has no hum even though the Power and signal grounds aren"t seperated ..... Just simple , quick, and dirty ..... Cheers
#2 |
Hi,Great Job Man. Thanks for sharing. Regards
Neeraj |
#3 |
You can always replace the jumper with a small resistor to separate the grounds.
The 5W 0,5R resistor is only necessary in parallel applications. Rating and resistance are too big and it touches Ci, which does not like heat. Rin should be connected between Cin and IC, not between input terminal and Cin. The way you laid it out, the filter frequency depends on the IC's input resistance instead of Rin. Where is Rb? Space for Cc against Rf disturbances, Rsn/Csn against oscillations and L/R against reactive loading should be provided. You should also state the biggest possible voltage rating for that design, which will be limited by the size of the 1000 µF capacitors.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 |
I don't like the layout..the input o/p r so close..kindly change the layout
SivanandBalan |
#5 |
I don't like it either.
A very poor implementation that ignores much of National's advice.
regards Andrew T. |
#6 |
Well I never claimed it to be a Good design , it is at the very best Functional .....
I Forgot about Rb so I soldered it on the bottom of the board but worked the same without it ......
#7 | |
best regards Kay |
#8 | |
Minion:
SivanandBalan |
#9 | |
Kay:
but seems to be colorful !! ![]() Efficient design (better use of copper)
SivanandBalan |
| Mini-A PCB'S | sandstorm33 | Pass Labs | 3 | 23rd March 2008 11:39 PM |
| the Very Mini Magico Mini | zei | Multi-Way | 7 | 11th February 2008 08:10 PM |
| Tom's mini-A | MikeW | Pass Labs | 9 | 5th March 2005 05:29 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.38160 seconds (15.05% PHP - 84.95% MySQL) with 11 queries |
