Old 2nd July 2009, 08:19 PM   #1
Default In-Speaker Amp and Power
I have a pair of JBL 4301 powered broadcast monitors and one of the amps went out. I'd like to replace the amps on both speakers. The speakers require around 50-80 watts to run. I'd like to put the power supply and amps inside of the speaker enclosure and I'm not sure if these gainclone power supplies would cause problems. The enclosure are sort of small, their only 8" drivers .I am also unsure as to which chip is best for me. I appreciate any help or advice.
Evan Livingston
Old 3rd July 2009, 01:20 PM   #2
AndrewT is online now AndrewT  Scotland
if you put the amplifiers and their power supplies inside the speaker box, how does the heat get out?
regards Andrew T.
Old 3rd July 2009, 03:07 PM   #3
star882 is offline star882  United States
star882's Avatar
Modern digitals run cool enough that heat is not much of a problem.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 3rd July 2009, 11:04 PM   #4
wazzy is offline wazzy  Zimbabwe
you could use a 'plate amp' design with an external heatsink. have done this myself a few time and it works pretty well.
Old 4th July 2009, 02:28 PM   #5
Like he said....
Worked a treat
Speaker for your low power amp? EmergencyDpt Chip Amps 3 28th August 2008 12:47 AM
need help!!speaker power mariusb007 Car Audio 16 27th November 2007 10:11 PM
Power output vs speaker power handling Bob0513 Chip Amps 4 5th November 2006 11:41 AM
? HT speaker loads and amp power 2Bit Multi-Way 2 8th January 2004 11:49 PM
Page generated in 0.09899 seconds (69.09% PHP - 30.91% MySQL) with 11 queries
