Old 1st July 2009, 04:46 PM   #1
sandyhooker's Avatar
Smile My Ref"C" PCB's
Would like to find a set of Twisted Pear Boards for the Ref C chip amp. Also would like to have copy of the schematic. I know there is a set of boards out there that hungers to be in Arizona!!
Thanks..
Old 1st July 2009, 05:53 PM   #2
bump!
Old 1st July 2009, 06:01 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Have you contacted Twisted Pear?
/Per-Anders (my first name) or P-A as my friends call me
Old 1st July 2009, 06:15 PM   #4
I checked their website and the item is not listed.I suppose an email is in order. I'm surprised that there are'nt more boards available for the LM3886 chip. Most use the original National Semi data sheet schematic which has some short comings.
Old 1st July 2009, 06:29 PM   #5
RIP
Twisted Pear will give you the artwork to make your own, it used to be on their site but it's gone now I think. You can try posting in the tradin post.
Best, Bill
Old 1st July 2009, 10:12 PM   #6
Originally posted by sandyhooker
bump!
Old 1st July 2009, 10:28 PM   #7
peranders's Avatar
If you search for a pcb with LM3886 you have plenty out there, a dozen at least including mine.
Old 2nd July 2009, 01:17 AM   #8
Thankyou very much..I am really not set up for PCB fab. I did it years ago with the Kepro negative system but ,now, would rather not get involved.Am thinking about going to the TDA 7293/94 as boards are available.
If someone had a set of boards utilizing a decent circuit I'd stay with the LM3886.
Thanks for your reply...
JT
Old 2nd July 2009, 02:20 AM   #9
As peranders said, a search will find you some. If you're looking for single chip per channel setups, two that come to mind right away are:
http://sjostromaudio.com/joomla/inde...d=65&Itemid=27
http://www.chipamp.com/lm3886.shtml
Old 3rd July 2009, 05:06 PM   #10
Default Re: My Ref"C" PCB's
Thanks..
BUMP BUMP!!!!!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 02:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 09:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Page generated in 1.02666 seconds (6.73% PHP - 93.27% MySQL) with 10 queries
