Old 1st July 2009, 12:34 PM   #11
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by ambed
Which ground are better star or ground like in pcb??
Personally I would swap the OG and the connection for SG. Let the signal ground sniff at OG. Right now you'll draw amperes via the SG connection => voltage drop.
/Per-Anders (my first name) or P-A as my friends call me
Old 1st July 2009, 01:04 PM   #12
Originally posted by peranders
Personally I would place the star ground under the output filter.
Peranders' suggestion is worth doing.
regards Andrew T.
Old 1st July 2009, 02:59 PM   #13
ambed is offline ambed  Latvia
To signal ground I must put audio signal minus and speaker minus?
Old 1st July 2009, 04:26 PM   #14
Signal Ground is the return for the signal input.
It is not the return for the amp output.
regards Andrew T.
Old 1st July 2009, 08:00 PM   #15
Im sorry, but I dont understand what did you mean whit output filter??
Old 1st July 2009, 09:41 PM   #16
the output filter is the pair of resistors that connect the amp output to the output terminal and to power ground.
regards Andrew T.
Page generated in 0.07792 seconds (76.18% PHP - 23.82% MySQL) with 10 queries
