Old 27th June 2009, 08:23 AM   #1
jmillerdoc's Avatar
Default DC offset 20V!!!
I have built several of Brian Bell's LM3886 Chipamps in the past. He was running a special where he was giving away a fre set of LM1875 PCBs with each purchase. I had collected several of these so I thought I would try one. After collecting all of the parts and using the build thread here, I had it all complete....so I thought. Tonight I finally got everything wired in the chassis (extremely tight fit, unique wooden chassis) and powered her up. Immediately from both channels I am getting the same voltage as my rectified voltage....20V! I am scratching my head and re-tracing everything and I cannot figure it out. Any stupid oversights I may have done? What would be a straight forward answer to why I am getting 20v as if there where no amp in between the speaker outs and the rectifier? Both boards are seperated in two small wooden eclosures on either side of the PSU. the only thing connecting them (really not a connection) is the 3 power leads + GND - . I must have done the same thing wrong on each side. I am pretty sure I followed the directions. Ant thoughts?
Thanks,
Jeff
Old 27th June 2009, 01:10 PM   #2
Zigis is offline Zigis  Latvia
You have disconnected one power leg or wire.
Measure +20 and -20 direct on chip power legs, check all connections.
Old 27th June 2009, 05:54 PM   #3
Check input resistor to ground ,make sure ikt is connected
DC Offset JannaCassandra Chip Amps 3 26th July 2008 04:20 PM
What is DC offset? spooney Car Audio 13 2nd March 2008 11:35 PM
Help With DC Offset Sybex23 Chip Amps 8 15th November 2004 08:11 PM
GC offset janneman Chip Amps 4 3rd July 2004 09:10 AM
GC very low DC offset matjans Chip Amps 7 22nd September 2003 11:24 PM
Page generated in 0.07115 seconds (69.66% PHP - 30.34% MySQL) with 10 queries
