Old 2nd November 2009, 04:00 PM   #21
I've bought several kits including a clone of an old but famous US built toobe preamp directly from China and so far no problems at all. The stuff has worked perfectly and quality has been very high. Delivery too has been quick.
Mark
Old 3rd November 2009, 08:08 AM   #22
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Originally Posted by jazzman06 View Post
I'm using something like this- sounds very clear!
tube is ECC88 ?or you can see it:
http://cgi.ebay.com/E88CC-6DJ8-6N23P...3A1%7C294%3A50
Hi Jazzman,
Do you think the Russian 6N6P is suitable for this buffer?
And what about to use the same power supply for the buffer and the power amp? Or if I use the same +/-35v for both buffer and the LM what kind of problems I face?
By the way, I dont understand too much from the tubes
Best regards,
Ozgur
Tube equal to one section of a 12AX7? Pyre Tubes / Valves 24 16th June 2008 10:02 PM
ECC83/12AX7 Tube test query waam68 Tubes / Valves 8 8th November 2007 08:52 PM
Help! first tube pre-amp with 12ax7 zafira1981 Tubes / Valves 2 8th December 2006 10:37 PM
Using a 6SL7 in a tube overdrive pedal instead of 12AX7? G Tubes / Valves 5 21st March 2005 12:34 PM
suitable preamp for a tube amp (kt88+12ax7) kevinkuang Tubes / Valves 6 17th March 2005 03:22 PM
Page generated in 0.06745 seconds (73.67% PHP - 26.33% MySQL) with 11 queries
