Old 25th June 2009, 04:00 AM   #1
klewis is offline klewis  United States
klewis's Avatar
Default Help with DC Servo for Current Feedback Opamp
I've built a preamp around the LME49713 current feedback op amp. The results so far look very good. I added a DC servo to manage the DC offset - which varies from -2mv to 19mv depending upon the volume pot setting. I used the LME49720 op amp for the servo. I simulated the following circuit and it show the servo correcting the offset. The actual circuit changes the offset to 32mv regardless of the volume pot setting. So, is some respects, it's working in that it's making the DC a constant value, but, it's not the 0 volts expected. Advice and critique would be greatly appreciated.
Ken
I used the LMH6723 current feedback op amp model for the 49713 and the op275 for the 49720.
Old 25th June 2009, 08:40 AM   #2
Should the DC servo for an inverting amp not also be inverting and act on the non-inverting input?
It is also advisable to use anti-parallel diodes between the servo's input pins to avoid overvoltage.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 25th June 2009, 10:26 AM   #3
Artie is offline Artie  United States
I've been reading up on CFB opamps too, and there's two things I've picked up on:
1. (This is taken directly from Linear Tech's "CFB Do's and Don'ts") "DO NOT PUT A SMALL CAPACITOR FROM THE INVERTING INPUT OF A CURRENT FEEDBACK AMPLIFIER TO ANYWHERE, ESPECIALLY NOT TO THE OUTPUT." The "all caps" is their form. Note your C4.
2. I don't believe a CFB opamp should ever be used in an inverting mode, due to the difference in input impedances. (This part hasn't been stated implicitly, but no app notes show an inverting circuit.)
Hope this helps.
Old 25th June 2009, 02:36 PM   #4
klewis's Avatar
Hope this helps.
Artie,
I read the app notes as well, so, I didn't explain the cap shown parallel with the gain resistor if for the simulation only, it represents the capacitance of the resistor and traces.
Audioman54 who helped develop the 49713 recommended the inverting configuration - like you I had the same impression. Have a look at the thread in the solid state forum "National Op amp inflation" you'll see his comments and my measurements from the preamp.
I tried simulating the it with the servo output going to the non-inverting pin of the preamp opamp and it offset the entire sinwave by about 4v positive.
Other thoughts - thanks.
Ken
Old 25th June 2009, 06:04 PM   #5
With the servo inverting?
Old 25th June 2009, 06:27 PM   #6
klewis's Avatar
I took the output from R21 and connected it to the non-inverting pin of U3 in the simulation and disconnected it from the inverting pin. All of the aforementioned was done with the simulator, not the physical circuit.
Old 25th June 2009, 06:30 PM   #7
klewis's Avatar
I think you have a good point here, though the non-inverting input behaves quite differently on a CF opamp compared to VF opamp. I'll post another schematic.
Old 25th June 2009, 06:41 PM   #8
klewis's Avatar
Here's the ouput plot from the first schematic simulation. It show the offset being injected and then corrected.
Old 25th June 2009, 06:42 PM   #9
klewis's Avatar
Here's the simulation schematic with the inverting servo acting on the non-inverting input.
Old 25th June 2009, 06:47 PM   #10
klewis's Avatar
Here's the output plot for the inverting servo configuration. It moves the offset but, just barely, certainly not back to zero. I used resistor values as recommended by national in AN-1192 figure 15. These are for voltage feedback amps.
opamp for DC servo lucpes Solid State 10 11th August 2004 10:33 AM
Current-Sensing Servo Feedback BAM Multi-Way 1 24th February 2004 11:18 PM
Adcom gfa-585 dc servo opamp georgehifi Solid State 16 1st November 2003 01:50 AM
Schematic for Servo opamp. sonnya Solid State 17 26th July 2003 04:38 PM
Page generated in 0.11539 seconds (84.96% PHP - 15.04% MySQL) with 11 queries
