Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 23rd June 2009, 03:49 AM   #1
Default Resistor sizes in chip-amps
Hi all, hopefully this isn't too dopey...
In most designs for LM3886 chips based on the reference designs from the spec sheets, I typically see 1/4 W resistors used for the signal paths and a 2W resistor specified for the Zobel.
Is there any reason for not using 1/8 W resistors in the signal path?
Also, has anyone tried lower wattage resistors in the Zobel circuit?
Old 23rd June 2009, 06:30 AM   #2
CJ900RR is offline CJ900RR
CJ900RR's Avatar
Send a message via MSN to CJ900RR
I have used SMD-resistors, 0,125W in the signal-path with no problems, and so does many commercial amps. The line-level doesn't require more.
For the zobel, it may need to handle high current sometimes, that's why you should have a higher watt-rating on them. The zobel is in the amplified area of the signal, witch can be several amps. That would destroy a low-watt resistor pretty fast...
Best regards, Calle...
Website is remade and updated, welcome!
www.leetmaa.se
Old 23rd June 2009, 06:37 AM   #3
Thanks Calle, that's what I thought about the signal path resistors.
I've seen some people using 1/2 W resistors in the Zobel, I wonder if anyone has had problems? It would seem that unless there was a constant source of oscillation, there wouldn't be much current in that path...
Old 23rd June 2009, 07:23 AM   #4
Dxvideo is offline Dxvideo
Dxvideo's Avatar
I ve burned some 1W 0R1s in my LM4702 amp.. But thanks god, after that event I've never used zobel in any amps..
Best regards,
Ozgur
Old 23rd June 2009, 08:18 AM   #5
Electrons are yellow
peranders's Avatar
Default Re: Resistor sizes in chip-amps
The power rating should be chosen for your needs. It's as simple as that. You'll have to do some calculating in other words. You should consider the power dissipation in the feedback resistors since you may have high AC voltage there. This is important if you'll choose to have low ohmish values.
The resistors should cope with 20 kHz at full power. That's the minimum. Make take can be seen below, R9-R11
/Per-Anders (my first name) or P-A as my friends call me
BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb, checking interest Sign up HERE
Rectifier bridge RFB03 Group Buy Round 2, checking interest Sign up HERE
Old 23rd June 2009, 09:49 AM   #6
digi01 is offline digi01
digi01's Avatar
Send a message via MSN to digi01
i use 0805 package resistors,no problem with 3886igc.
good work!
Zang
DIY ALBUM
UCP preamp proceed
Old 23rd June 2009, 12:52 PM   #7
kscharf is offline kscharf
kscharf's Avatar
Zobel networks are only one means of stabilizing amplifiers. Many people (Peter of AudioSector) don't like them. Another way is to put a small rf choke in series with the output to the speaker. Something like .4uh to 1uh is a typical value. Winding some #24 wire on a 1W resistor (can usually be any value above 10 ohms) makes a good choke. In a bridged amp it's usually not necessary to have a choke in both sides, just one.
Old 23rd June 2009, 02:00 PM   #8
Default Re: Re: Resistor sizes in chip-amps
The size of the Zobel resistor depends on the possible output swing. If 1/4 W burns on an LM3886, there is something severely wrong with the amplifier. Some people prefer to increase the resistor rating instead of looking for the fault and correct it.
An LM4702 cannot be compared to an LM3886 in that regard. 0R1 is also not a typical value for a Zobel network. Not really surprising that it didn't work. National shows 3R3 and 20 nF in their reference project. Shunning Zobels is the wrong conclusion from your experience.
.. if you use the amplifier to reproduce test signals.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 23rd June 2009, 02:17 PM   #9
peranders's Avatar
I think it's a bad idea to design parts which you easy can distroy. 20 kHz full power is a reasonable power size of the resistor but 100 kHz is better but the trade of is probably worse HF properties of the Zobel.
Old 23rd June 2009, 02:44 PM   #10
jackinnj's Avatar
The resistor lowers the "Q" of the coil -- without it you can get a sharply tuned resonant circuit consisting of the inductance of the coil, the capacitance of the speaker loads and whatever reactive elements you have on the speaker end.
I wouldn't skimp on wattage of the RC snubber -- you can get the 2W Vishay PRO2 series which are about the size of a 1/2 W carbon comp resistor.
TinTin -- banned in Brooklyn
Thread Tools
So many chip amps ? Buzzy Chip Amps 6 31st August 2007 09:29 AM
New to Chip Amps skidave Chip Amps 14 28th July 2007 07:15 PM
Help... Need Chip amps game_master Chip Amps 1 9th March 2006 04:14 PM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 12:50 PM
chip amps for ESL's? Few Chip Amps 3 30th April 2004 12:30 PM
Page generated in 0.26926303 seconds (74.40% PHP - 25.60% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
