| Chip Amps Amplifiers based on integrated circuits |
#31 | |
The bolt on bit is to the right of C5/R3 and C6/R4. The end of the chipamp.com PSU is represented by the circular features on the rails and PGNDs. The stuff to the right of these features has been lifted from the application notes for the chip. Clearly, if one were designing this from stratch, a different approach would be taken. |
#32 | |
Normally, no capacitors are needed unless the device is situated more than 6 inches from the input filter capacitors in which case an input bypass is needed. An output capacitor can be added to improve transient response, while bypassing the adjustment pin will increase the regulator's ripple rejection. |
#33 |
I'm hoping to bypass all of this agro by simply sticking to 8 ohm speakers if I can. But an interesting diversion anyway.
I think I've decided on the cases I'm going to get; a couple of the Galaxy Maggiorato with the 10mm black front panel at 330mm by 170mm. Trouble is that these aren't cheap at around £100 delivered. Taking to account the cost of the kit (£67), the transformers (£65), the cases (£100) and the extra bits and pieces (£70), it's all looking a bit expensive at around £300 all in. On top of this, if I build an Aikido based preamp using two of the same cases above, I reckon the total cost of power amp and preamp will be upwards of £600. This is getting into serious kit territory...with a Naim Nait 5i coming in at only £765. Clearly, there isn't the same level of satisfaction involved in just buying a commercial amp...but the commercial kit does have resale value. Do you think that the chip amp dual mono power amps and an Aikido preamp is going to be in the same territory as the Naim Nait in terms of sound quality? I'd be grateful for a little reassurance at this point. |
#34 | |
Look at the amplifier cost (£67) compared to the total budget (£600). Double the amplifier cost, nay go the whole hog and triple the amplifier cost. Spend £200 on a very good discrete amplifier and you will not regret it. But, first build your chipamp without all the expensive add-ons and have a listen.
regards Andrew T. |
#35 | |
If you look at the schematic for the TREAD here I thought the snubbers were C1 to C4. But it seems that these are simply to suppress noise around the bridge and are optional. Why haven't I seen any other schematics which use this approach? |
#36 | ||
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#37 | |
One of the reasons I'm going for the slightly larger case is that it will allow me to change the amplifier at a later date. Clearly, there are a number of options. I could use multiple LM3886's as many others seem to have done. Or one could go discrete. I'm not sure if my transformer would support the former but it might support the latter. I have had a go at discrete circuits in a limited way (see here) and enjoyed the experience. But yes, I'll build the chip amps and see what I think. Will the result be comparible to the Naim Nait? |
#38 |
Well, I've taken the plunge and bought the cases. I went for the 330mm x 230mm in the end. With the 10mm thick front panels and 8 feet, the total cost, including VAT and delivery was £130.94. Gulp!
#39 |
expect ~30% for the amplifier, another ~30% for the chassis and heatsinks, another ~30% for the PSU and ~10% for case hardware.
regards Andrew T. |
#40 | |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 08:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 07:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 01:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| Page generated in 0.12532 seconds (83.36% PHP - 16.64% MySQL) with 11 queries |
