Old 19th September 2009, 02:12 PM   #371
PJPro is offline PJPro  England
PJPro's Avatar
Or indeed, this one from jaycar (uk). It even looks the same!
Old 20th September 2009, 09:11 AM   #372
Stuey is offline Stuey  Australia
PJ, if you're looking, I suggest a search on this forum. There have been quite a few threads on soldering stations over the last while.
I looked at Aoyue (which are supposed to be pretty good) and Hakko (the dog's bollocks) but ended up with a cheapy when a $99 (at the time) iron by a local vendor Altronics was reduced to $49 with three different tips. It does the job well.
http://www.altronics.com.au/index.as...=item&id=T2443
Stuey
Old 20th September 2009, 09:50 AM   #373
akis is offline akis  United Kingdom
I bought the one from Maplin, special offer at 50 pounds, it is quite a beast, heats up in a few seconds, reaches something silly like 400C and I am generally very happy with it. Makes a quite hum when it is heating.
http://www.maplin.co.uk/Module.aspx?ModuleNo=218050
Old 20th September 2009, 06:56 PM   #374
I picked up an analog Weller temperature controlled station for $100 recently. WAY better than the 60W Radio Shack POS I was using prior. The Radio Shack one is still good for larger tasks, like ground plane connections, as it has a much bigger tip.
Tyler
Old 21st September 2009, 06:25 AM   #375
Originally Posted by akis View Post
I....reaches something silly like 400C and I am generally very happy with it. Makes a quite hum when it is heating.
Like when Marty McFly switches on his guitar amp in Back to the Future?
Old 18th April 2010, 11:16 AM   #376
PJPro's Avatar
I abandoned this project last year because, err, I was having trouble wiring it together. The insultated crimp quick connectors just wouldn't connect adequately for my liking and I felt the hookup wire I was using was a bit pants.
I've resolved the hookup wire issue and bought some 19 strand 20AWG silver telfon wire for the power circuits and some 24AWG silver kapton wire for the signal circuits from Navships (John's Wire Shop) off ebay.
I now need to sort out some crimp quick connectors....and again I'm having difficulty so would be grateful for some advice. I'd like to be able to crimp and then solder the connectors (vibration isn't a problem so I am content that soldering is OK), so I need connectors which will allow the insulator to be removed and then replaced or connectors where the connector and the insulator is purchased separately. Anyone care to suggest some candidates? I'd be really grateful if you could post a link.
Incidentally, these quick connectors need to accept a tab size of 6.3 x 0.8 mm. I do need other sizes, but if I can find one make/model which is appropriate, I hope to be able to buy others within the same range to suit my needs. I don't care how much they cost or where I buy them from....they just need to be right.
Thanks for any suggestions.
Old 18th April 2010, 02:38 PM   #377
Usually it is either crimp or solder.
6,3 mm rings AMP connectors which is now under the roof of Tyco Electronics. Should be available in most electronic stores and there is also a list of vendors on the homepage. They come in all forms isolated, non-isolated or with a movable isolation sleeve.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 18th April 2010, 06:56 PM   #378
PJPro's Avatar
Thanks for your reply....and I've taken a look at that link. But how on earth can I tell which have the movable isolation sleeves? I just can't see it and it doesn't appear to be an option which I can filter on. Apologies for my shocking ignorance.
Old 18th April 2010, 08:28 PM   #379
You need to buy non-insulated receptacles and the separately available insulating sleeves. This source offers the sleeves as part no. 735529. They only have the receptacles 2,8 mm wide, though.
Old 18th April 2010, 08:32 PM   #380
mjf is offline mjf  Austria
hello.
i often use heatshrink for isolating connectors.............
greets
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 08:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 07:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 01:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Page generated in 0.10777 seconds (84.99% PHP - 15.01% MySQL) with 11 queries
