| Chip Amps Amplifiers based on integrated circuits |
#291 | |
#292 | |
I agree that it is possible to polish a turd. But however shiny, it's still a turd.
#293 |
Regarding the earth discussion:
"a direct mechanical link from the supply earth wire to the metal chassis". The above, which is what was recommended above is not near good enough in my opinion. I am not trying to be awkward. The above should be something like: "a direct mechanical link from the supply earth wire to the metal chassis AND to all other conductive elements on the chassis which the user may touch or work with, eg shielded wires, cables, probes, your electric guitar's lead, the electric guitar's strings, bridge and buckles, your amp's metal knobs and so on". The advice to keep the RCA plugs and other interconnects separated from the earth (to avoid ground loops) kind of breaks it for me, I can imagine plugging a guitar into your amp and getting electrocuted. Regrding the slow start circuit, would you like to be a guinea pig ? I have designed one and amabout to build it, the PCB should be arriving soon, it looks like this (I am sure I have posted this before somewhere here). What it does is provides a 12 V on-off switch, so you do not run 240V wires inside the enclosure and onto the front panel (imagine spilling your pint of beer) and additionally a slow start by the means of two relays.
#294 |
By the way, remember that workshop you found near you to make you an aluminium panel? Do you think they'd be able to construct an alumunium enclosure for my guitar amp? I need an encosure to measure 85 cm across, 40 cm depth, and 7cm height - and such things are hard to find :-)
#295 | ||
BTW, the E24 provides 12 VDC for the switch and allows use of momentary-contact switches (see here). Incidentally, Headwise appears to be back online. Thanks. |
#296 | |
The E24 also provides thermal auto-shutoff. See the quote below from AMB taken from the Headwise forum......
If I do go ahead with the thermal auto-shutoff and, given the operating temperature range of the LM3886 being -20 to 85 degC, should I go for the STO-180 (which opens at 79 to 85 degC) or the STO-170 (which opens at 74 to 79 deg C). My view is to go with the STO-170. Why? Well I'm assuming I would mount the sensor on the heatsink (or chip clamping bar) as close the the chip as possible but not actually on the chip. The lower temperature rating would allow for this distancing from the chip itself. Thanks for any advice/opinion. |
#297 | |
* this means there is a whole bunch of electronics in the way, additional PCBs, wires etc, there is additional complication and more things to go wrong, eg imagine if you have a bad solder connection, or the bridge is defective and so on. You'd never know until it was too late. Also, did you see my question about the aluminium enclosure? :-) |
#298 | |
That is a cool feature to have, the ability to sense that something has gone wrong and as a last ditch effort we are switchign off. Except - if you have a proper heatsink, is it theoretically possible to heat it to 75 C ? Do some analysis to see what sort of power you'd need for the given heatsink and whether the chip would have shutdown already before that. Heatsinks have a C/W rating if I remember correctly, and the LM3886 will say how many watts it will allow before one of the trigger conditions makes it switch off, eg shorting the output or driving it with a pure square wave etc. Nah, I think it is not needed, you'd be better off using my board. :-) |
#299 | |
I suspect you'll have to sort out the finishing yourself although anodizers aren't hard to find. I'd be interested to know what they quote you for the work. I'm considering using them in the future. |
#300 | |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 08:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 07:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 01:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| Page generated in 0.14386 seconds (82.73% PHP - 17.27% MySQL) with 11 queries |
