| Chip Amps Amplifiers based on integrated circuits |
#271 | |
Hi Stuey,
As a subscriber to that magazine (EDN), would have hoped that they also judged the designs on whether they were acceptable or not if you actually attempted to pass equipment for safety certification. They normally have great ideas, thought provoking at least. You know what this situation proves? Safety organizations are a necessary evil simply to protect everyone from others who simply can't see beyond the end of their pencil. Hi PJPro, Those are great looking buttons, but last time I checked, they were a tad bit expensive. Really nice switches though. I think you have the right idea there. To take stock of what your overall plans are, and how you will work towards them through time. As far as capacitors go, reasonable film types will be better than a tantalum or electrolytic. Stay away from stacked ceramic! Generally speaking, the lower the K of the dielectric is, the better sounding the capacitor should be - within reason. That is a very general guide. Also watch the dielectric absorption, that you want to keep low as well. Don't sweat it though, caps are easy to change, and you may find that the differences between some are not audible. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#272 | ||
Chris, do you have a view on the ferrite beads as recommended by infinia. I don't doubt his word. I'd just like a second opinion. Failing that, I'll just buy them and experiment. I'd also be grateful for a steer on the inductor. Thanks. |
#273 | |
Thanks Stuey. If I can track down something appropriate it'll help me narrow down a suitable component here in the UK. |
#274 |
OK. The ESP soft start boards are ordered. I'll wait until I've read the accompanying notes before I start to order any of the required components.
#275 | |||
Hi PJPro,
Off the cuff, most plastic dielectric types will commit fewer sonic evils than electrolytic or ceramic types may. I was trying to give you the tools to determine your local availability and whatever the future holds. I was not trying to be cryptic at all. Epcos does make some good ones for example. Quote:
Generally speaking, if you are passing any DC current, you want a gapped (EI) core. If the current will be AC only, a toroid might be a good bet. There are instances where toroid transformers have problems in AC supply for power due to "effective DC " caused by line waveform distortion. Personally, anything to do with AC power gets an EI core part in my reality. -Chris
#276 | ||||||
See the following quotes for the history on this, which stemmed from the filtering power inlet modules and other sources of RF. Quote:
Hopefully the above quotes will give you a quick way to understand where I am coming from. Thanks for any advice you are able to provide. |
#277 |
1) L1 construction is in the ESP link I provided (handwound air coil around resistor body). Hang it off the PWB to the output jack or a standoff.
2) search DIYA -solid state forum for individual posts using terms like "inductor+zobel+RFI" if confused after reading go to step 3). 3) It's included in National Semis test circuits and it's the right output circuit/network to use consisting of 4 parts. 4) It looks pretty cool too.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#278 | |
That Jaycar link IS in the UK - it's their UK mail order site. That's why I tried their UK site (a mirror of the Aussie one). I think they have a presence there nowadays.You'll get access to the ESP secure site once you've ordered. The page for Project 39 has VERY comprehensive info, including a very clear drawing of how to wire it up to the switch and IEC socket. Cheers Stu |
#279 |
2watt resistor with 11-12 Turns of magnet wire
#280 | |
Thanks Infinia. |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 08:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 07:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 01:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| Page generated in 0.14424 seconds (82.95% PHP - 17.05% MySQL) with 11 queries |
