| Chip Amps Amplifiers based on integrated circuits |
#21 |
Couldn"t you also just use a Lower Gain on the Tweeter chipamp to get less output power ??
#22 | |
#23 |
They are unstable at gains under 10 I think but you could run the Tweeters at 15x and the woofer at 30x for example .....
#24 |
..or attenuate the tweeter in an active crossover with a potentiometer/trimmer, which makes it easy to adjust later on. On the other hand there seems to be only a capacitor in front of the tweeter, so maybe the two drivers are already of similar sensitivity. Then they would need the same gain and level.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#25 |
Today I woke up with a thought in my mind.. Try what AndrewT said..
So I remembered my father's 20-year Rising Hi-fi system (mine also ) wich has 4 ouputs..So I listened both configurations for a while.. And, the first impression is: Paralelled: Good sound. Very good bass. Treble could be a little more clean, though... Sperated inputs: The bass is a little less loud but the treble is way way better! Of course the treble is, as Redshift187 mentioned, a little overpowered but I compensated that with equalization just to have a better idea. (I found this speakers quite impressive for they size ) Have not decided quite yet but I think the bi-amplified config is a good choice.. I'd have to make a crossover though... RJ |
#26 |
there's a first conclusion: bi-amplifying a bi-wireable speaker makes the sound output different. Many builders and listeners on this Forum say this conclusion is either impossible or a waste of resources. How does one amplifier (non parallel) compare to two amplifiers driving the separated terminals? |
#27 | ||
Maybe it's just my constant search for sound perfectness..Or at least anything close to it! ![]() I'm sure bi-amplifying is quite more expensive and laborious, but in my opinion, it's definitly worth it!! Anyway, let's think: We guys make what? an amp per year, perhaps! Technics/Panasonic engineers make - just guessing here - some dozens/year ?! I really don't think those guys would make bi-amplified systems just for fun!! It's only my guess though...Quote:
RJ. |
#28 | |
#29 |
But that's precisely what I've done!!
Sorry if I didn't express my self in a better way.. RJ. |
| How many Gainclones can be powered off a single rectifier? | AJ Bertelson | Chip Amps | 13 | 4th December 2008 08:19 PM |
| why are bridged gainclones less popular than parallel ones | ionomolo | Chip Amps | 4 | 16th November 2007 07:32 PM |
| 2 Woofers in Parallel Config - 4 Options | HiFiNutNut | Multi-Way | 16 | 23rd November 2006 03:23 PM |
| Tripath TA2024/20 Bridge/Parallel Config | john65b | Class D | 16 | 6th November 2005 06:06 PM |
| Nice simple parallel bridge config | vortech | Chip Amps | 0 | 5th August 2005 01:08 PM |
