| Chip Amps Amplifiers based on integrated circuits |
anyone else ever try running one of these off 38-0-38v? i thought that i would try it out, i'm using it with my studio monitors and it sounds awesome!btw i have pretty large heatsinks and fans, essential at this voltage! no reliability issues yet!
#2 |
38-0-38V
I presume you mean DC voltage. That is well within the maximum stated by National for an operational amplifier. When does the PSU measure +-38Vdc? when the mains voltage is nominal or when the mains voltage is at minimum supply voltage or when the mains voltage is at maximum supply voltage. or when the amplifier is at quiescent state or when the amplifier is producing maximum power or some combination of these different operational conditions? What is the ripple voltage at the supply pins when you measure the average DC voltage?
regards Andrew T. |
#3 |
yes those are the dc voltages, it is 2 volts down at maximum power, i have a power conditioner that all my av stuff goes thru so the voltage at the mains side is very stable.
#4 |
does 2V down when under power mean
+-38Vdc quiescent and +-36Vdc when delivering power or +-38Vdc when delivering power and +-40Vdc when quiescent? Does your power conditioner guarantee that your mains voltage does not vary as the Power Company allows the supply voltage to change under varying supply and demand conditions?
regards Andrew T. |
#5 |
I ran a LM3886 off of a +/- 42v supply for a while but I had heat problems and the ocational wierd noises would creap in at high volumes ....
I ended up just useing the +/-42v supply for a TDA7293 instead which can handly these voltages and puts out considerably more power at these Voltages... Pluss for me personally the TDA7293 is a much more musical sounding chip than any of the LM38XX chips but a bit harder to use..... Cheers |
#6 |
i have not used tda 7293 but i've used tha 7294 to me the lm3886 has a warmer sound.
| voltages on a zen v.9 | gionag | Pass Labs | 5 | 28th May 2008 04:42 PM |
| ESL voltages | Fanuc | Planars & Exotics | 5 | 11th February 2006 08:36 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| PSU cap voltages | lawbadman | Solid State | 4 | 3rd January 2004 01:37 PM |
| TV set voltages? | setmenu | Everything Else | 10 | 20th March 2003 02:36 AM |
| Page generated in 0.08901 seconds (72.05% PHP - 27.95% MySQL) with 10 queries |
