Thread Tools
Old 19th June 2009, 09:36 AM   #1
digi01 is offline digi01
digi01's Avatar
Send a message via MSN to digi01
Post universal chip pre-amp project
there are lots of wonderful opamp manufactured by nsc,ad and ti.i plan to make a universal pre-amp basis on the chips.
design goal:
1,simple configuration,
the unit will use 2pcs universal dual opamp.
2,pure dc coupling,
the unit will not include caps in the signal route.no high(low)-pass filtering,dc block.maybe setup some break points for unstable op.
3,diy friendly,
make the pcb compact,easy install,easy embed.
-zang
Old 19th June 2009, 01:01 PM   #2
Atilla is offline Atilla
It would be nice to be able to configure the opamps as unity-gain buffers in case you wanted a buffered preamp without gain.
Actually that's something I'm working on right now, but I plan to use dedicated buffer chips instead.
Old 20th June 2009, 10:56 AM   #3
AndrewT is offline AndrewT
Default DC coupled pre-amp
DC coupling requires DC detection and some form of input and/or output muting if the detection activates.
Consider adding a DC servo to minimise the "normal" offset.
Ensure you have adequate RF filtering.
I have now done some smd assembly using To23 and 805 resistors/caps. Don't be afraid to use these sizes. It was relatively easy for my magnifying glass assisted old eyes.
regards Andrew T.
Old 22nd June 2009, 12:43 AM   #4
digi01's Avatar
thanks for the suggestions,hopefully i can completed a backbone of schematic this week.i already have some pcb lay out ieads.
any suggestions?
Old 22nd June 2009, 09:08 AM   #5
digi01's Avatar
here is the sch.extreme simple?
this is a balance/unbalance design,one gain stage with one buffer output.
Old 22nd June 2009, 09:26 AM   #6
Ted205 is offline Ted205
Ted205's Avatar
why have you used an output buffer ?
Old 22nd June 2009, 03:41 PM   #7
If you want to add a dedicated buffer after the opamp, you might want to consider to put it inside the feedback loop of the opamp. Look at the LME49600 application notes for example, I find it to be more beneficial.
Old 23rd June 2009, 12:49 AM   #8
digi01's Avatar
the buffer stage was setup for connection friendly,it can fix impedance problem of the after device such as connection cable,volume pot,power amp...
this is a design case.the u1a,u2a voltage gain is isolated with the u1b,u2b buffer.
i have tested the overall loop configuration.it work good but it is no good for pre-amp.
if i make a headphone amp i will use overall loop.
Old 23rd June 2009, 05:35 AM   #9
Allright, that's good to know, thanks
Old 23rd June 2009, 08:50 PM   #10
lgreen is offline lgreen
lgreen's Avatar
Why are R1,R2, R9,R10 at 950 ohms? Shouldn't they be more like 100 ohms?
My DIY audio projects- PartTimeProjects.com.
Thread Tools
Which Chip for first DIY project? systemerror909 Chip Amps 3 9th January 2006 04:32 AM
Project - Universal CD Controller? lgreen Car Audio 1 22nd September 2003 12:20 AM
new project - chip amp?? yuval Chip Amps 3 14th July 2003 12:47 AM
A new chip amp project JOE DIRT® Chip Amps 11 17th June 2003 01:56 PM
Page generated in 0.10444403 seconds (100.00% PHP - 0% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
