Old 24th June 2009, 11:50 PM   #21
Put me down for Beta testing this board as well. Looks very exciting!
Old 25th June 2009, 03:47 AM   #22
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Originally posted by tent
sounds interesting.. would you be able to provide pcbs?
tent:wq
Yes,i would like provide pcbs.i have sent the UCP_v0.1 cam file to the pcb house.
P.S.
for a completed design.i have no idea about the power supply part.i will try standard fix regulated psu or batteries.
i think DC detection,RF filtering is useful function too.thanks A.T.
i do not like dc servo,it is too technical,short of human interest.
zang
Old 25th June 2009, 08:00 AM   #23
digi01's Avatar
Atilla,
for you information,the attached is a original pcb work of ucp_v0.2.i use smt resistors.
Old 25th June 2009, 08:01 AM   #24
digi01's Avatar
bottom layer
Old 25th June 2009, 08:02 AM   #25
digi01's Avatar
top layer
Old 25th June 2009, 08:24 AM   #26
Electrons are yellow and more is better!
peranders's Avatar
Nice work but have you checked the trace width of the output? Very thin. I would also make the solution more compact. Put the buffer closer to the opamp.
/Per-Anders (my first name) or P-A as my friends call me
Old 25th June 2009, 08:24 AM   #27
digi01's Avatar
here is smt version of ucp_v0.1,all resistors is 0805 packaged.
it is very compact very simple.pcb size is 40mm x 40mm.
have fun
Old 25th June 2009, 08:25 AM   #28
digi01's Avatar
bottom layer
Old 25th June 2009, 08:25 AM   #29
peranders's Avatar
Where did the buffer go?
I would recommend you have to have more isolation between the screwholes and the groundplane.
Strive to have all SMD parts on the upper side, more practical.
Have the main groundplane on the solderside but you can also have groundplane on the top side but it will hardly be a better ground but it looks nice.
The hot relief pads for the connectors have very thing traces. You can have fatter hot relief at some pads you know. The ground connections could be better and you could also tune the pads size. I think they look rather big right now.
Old 25th June 2009, 08:34 AM   #30
digi01's Avatar
P-A,
thanks for the comment.i use 20mil width track in the signal route.it is a decent value.
P-A,
there are two design.the basical design(ucp_v0.1) is simple 2 dual opamp.the other design(ucp_0.2) is opamp gain stage with LME49600 buffer output.
Zang
Which Chip for first DIY project? systemerror909 Chip Amps 3 9th January 2006 05:32 AM
Project - Universal CD Controller? lgreen Car Audio 1 22nd September 2003 01:20 AM
new project - chip amp?? yuval Chip Amps 3 14th July 2003 01:47 AM
A new chip amp project JOE DIRT® Chip Amps 11 17th June 2003 02:56 PM
Page generated in 0.11774 seconds (82.82% PHP - 17.18% MySQL) with 11 queries
