| Chip Amps Amplifiers based on integrated circuits |
#151 |
On the other hand...Digi's bridge module would be perfect for the My Ref C and simplifies things with one power supply for both channels...
#152 |
hello i am back.i have a new stuff.
this DUAL power supply is for universal using.although it is a typical application of the fixed regulator chips,i plan everything.i am pretty happy when i got the pcb and have it running ![]() the pcb size is as same as UCPv1 & UCPv2,the module have five output ports. -zang |
#153 |
wow nice work digi!
"I Love To Camp!" "Comensing Shock Therapy!" |
#154 |
Active regulator in mini?...with up to 3000uf per rail available, or whatever capacitors fit the board?
Simply brilliant! Those are additional outputs? For a minute there I thought the extra pads on the output traces were for shunting LED's. Can that be done? Last edited by 40 watt; 24th March 2010 at 07:30 PM. |
#155 |
Is this the little bug for B1, I assume the bridge rectifier:: Little Bug
...60 cents. ...83 cents from another manufacturer. both at Digikey. For this I could probably recycle a transformer from an older dead Philips CD player I have, maybe. Somehow, I have to wrap my head around the idea of 60 cents vs $1.23 X 8 [$9.84] for MUR86O's. The building of many active speaker systems just became more practical. ...looking closer at the traces the AC in are on diagonal corners. Hmmmm.... So much to learn and experience. Last edited by 40 watt; 25th March 2010 at 12:31 AM. |
#156 |
This one's a 2-amp but it appears to have the right pin pattern with AC on diagonal corners. 5mm lead spacing?
79 cents at Mouser \ 1.5 amp 200V for 48 cents. With the regulators and diodes this would be a great power supply. Frees up cash for premium capacitors...or not. Last edited by 40 watt; 25th March 2010 at 01:08 AM. |
#157 | |
some small kind computer caps 2200uf/16v will fit the board for a purpose of +/-12VDC output,using LM7812/LM7912 regulator. the extra pads on the output traces were for four 3pins sip header.they are very useful board to board wiring & do some digital kind stuff. the B1 is a column bridge rectifier,5mm lead spacing. thanks for the comment about the layout,i am enjoy this thing zang
#158 |
i recommand use tantium caps for C5,C6.
#159 |
I think this from the National App notes explains the diode and the 10uf output capacitor. For protection against a shorted input to ground. Nice.
#160 | |
After the smoothing task is complete, there is only DC, and then the caps can be 16vdc rated. |
| Which Chip for first DIY project? | systemerror909 | Chip Amps | 3 | 9th January 2006 05:32 AM |
| Project - Universal CD Controller? | lgreen | Car Audio | 1 | 22nd September 2003 01:20 AM |
| new project - chip amp?? | yuval | Chip Amps | 3 | 14th July 2003 01:47 AM |
| A new chip amp project | JOE DIRT® | Chip Amps | 11 | 17th June 2003 02:56 PM |
| Page generated in 0.12408 seconds (68.90% PHP - 31.10% MySQL) with 11 queries |
