| Chip Amps Amplifiers based on integrated circuits |
#91 | |
But I have a feeling it will be a little better when in an enclosure and a chassis ground (and resistor?) is used. I need to track down the mains power issue (6v between neutral-ground and 30v between hot-ground)and there is no ground behind the wall plate there. |
#92 | |
for low gain setting,you have to apply deep feedback to the opamp that is no good. the UCP preamp was designed for work under tough applications.it is not only for driving chip based power amp but also for driving solid & tube based power amp.some power amp have an low or nonlinear input impedance so that usual sources can not drive the input perfect.the preamp allows use of such devices without worry about impedance issue. can you test below configuration? (1)CD player ->attenuator->LM3886 poweramp (2)CD player ->attenuator->UCP preamp->LM3886 poweramp (3)CD player ->UCP preamp->attenuator->LM3886 poweramp the outputs on a source are often lower sound quality than fixed outputs.some sources have nonlinear output impedances which are not perfect for driving a power amp directly. Zang |
#93 | |
you can modify the gian via adjust R5,R7,R6,R8.the preamp is a two stage device,voltage gain + buffer stage.for make this unity gain,set R7,R8 as 0ohm is a simple way. |
#94 |
Good project. How much is the cost of the finished unit?
#95 |
Well,
I just ordered the board, the parts to stuff the board from mouser, and the stuff to stuff a PSU board I had left over from a gainclone project - basically the Carlos Filipe circuit. The board was $20 Components to stuff UPC and PSU(including 2 OP2227P) $35 still need a xformer, and misc jacks, plugs, fuse holders etc along with enclosure, pot, and anything else I neglected to mention. probably another $100 or so. All in all I am looking forward to this project for about $155...maybe less if I can repurpose an enclosure I have kicking around. |
#96 |
Hi all,
I finally got some time to continue this project.. now populating my 6 channel pre amp with three of those pre-amps using LMs... The attenuator is in good shape now.. Currently I'm struggling not having Hum and noise.. unluckily I do not know if I'm doing some earth ground wiring wrong or my implementation with PSU and toroids is wrong...... Anyway what I wanted to ask was: I was thinking also about putting a headphone jack in the box... ))) Do you have a suggestion on how I could implement a headphone in this implementation? Something not too complicated..Thanks, tent:wq |
#97 |
I knew you were still on here DIGI!
Glad u are still here, are you making boards for this project ? Jase
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#98 |
![]() VERSUS The PSU board I have leftover from my chipamp.com project is the one I want to use for the UCP. I notice that there is a difference in the Carlos Fillipe circuit with the chipamp.com version having a +PGND and a -PGND. How would I properly hook up the UCP to this PSU board? Last edited by cjkpkg; 3rd December 2009 at 02:10 AM. |
#99 |
OK,
After studying the layout of the LM3886 amp board it looks like the +PGND and the -PGND are not isolated from each other. Would it be as simple as just twisting the +PGND and -PGND together and connecting them to the ground of the UCP? |
#100 |
Yes, it is really that simple.
Any solution is a compromise. |
| Which Chip for first DIY project? | systemerror909 | Chip Amps | 3 | 9th January 2006 05:32 AM |
| Project - Universal CD Controller? | lgreen | Car Audio | 1 | 22nd September 2003 01:20 AM |
| new project - chip amp?? | yuval | Chip Amps | 3 | 14th July 2003 01:47 AM |
| A new chip amp project | JOE DIRT® | Chip Amps | 11 | 17th June 2003 02:56 PM |
| Page generated in 0.10224 seconds (82.01% PHP - 17.99% MySQL) with 11 queries |
