| Chip Amps Amplifiers based on integrated circuits |
#11 |
It sounds great, but I've never built anything else to compare it to. I chose my own components based on quite a bit of research and leaned toward good value. I used 2x 15,000 uF caps on the power supply board (1 board for 2 channels, really abusing the power supply when I turn it up all the way) and 2x 1,000 uF on each amp board. I compared a couple of different power supply setups. You can read about it here:
Breaking all the rules, a "custom" bridged story In a couple of weeks I will have built a LM3886 DC servo design to compare it to. |
#12 |
is it really a 29-0-29 transformer?
Measure the input mains voltage and the output secondary voltage with the secondaries unloaded. Calculate the unloaded voltage for the nominal mains input voltage. This answer is the rated voltage times the regulation factor of the transformer. Vac unloaded = Vac Rated * [ 1 + regulation ] * Vac mains actual / Vac mains nominal. Now calculate the Vac unloaded for maximum tolerance mains supply voltage (in the UK this is 254Vac for a 240Vac supply). Use this to determine the worst case voltage that will be applied to the rectifier.
regards Andrew T. |
| LM4780 SS Pcb | pinkmouse | Chip Amps | 67 | 31st January 2011 12:35 PM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| LM4780 preamp Suggestions? | Wynand | Chip Amps | 13 | 17th January 2006 04:25 PM |
| My Lm4780 | 96802 | Chip Amps | 2 | 11th January 2006 09:41 PM |
| Page generated in 0.06488 seconds (72.70% PHP - 27.30% MySQL) with 10 queries |
