| Chip Amps Amplifiers based on integrated circuits |
#21 |
Dremel with cutting disk on high speed takes about 2 mins on thin sheet steel. Needs about 4 disks, and safety glasses are essential since the disks
can fly off in pieces. Black Russians greatly improve the smoothness of the cut. |
#22 |
Abrasive cutting disks don't work well with aluminum. (Remember metal shop? Touching the grinding wheel with aluminum would get you in BIG trouble...).Even with steel, I find 'em a bit scary.
Drill, jigsaw and a bit of file work will do the job on steel. Hand nibbler is good with aluminum- I'm pretty sure my cheap nibbler wouldn't handle steel. If you think it should take you 5 min, it's a real PITA. If you relax and figure it will take 20-30 min to do a proper job, no problem. Anyway, the flange on the jack will hide some small mistakes. And you can make big holes smaller with Bondo..... ;-) |
#23 | |
![]() Done with the Dremel: NPX_01185.JPG 16awg stainless steel. Used less than one thin disk. Aluminum: _0035.JPG The square switch cutouts were done with the Dremel and touched up with a file. Used 2 disks, one for each cutout. Like all tools, it takes practice to get good results. |
#24 |
I've never thought of any other way than doing it with a Dremel. The price of a punch buys an awful lot of cutting discs...
![]() I cheat a little and print out the cutting template on to self-adhesive labels, then follow the lines closely. Now that I've had a bit of practise, I can usually get away without filing anymore.
Experience is what teaches us to make a different mistake next time... |
#25 |
I usually drill four holes then cut the shape out using a carbide hacksaw blade[the type usually used for cutting shapes in ceramic wall tiles] and then finish to size with a file. The carbide blade seems to work well with up to 3mm aluminium. I no longer use steel.
#26 |
For aluminum chassis I have had good luck using a coping saw with a fine tooth blade. I usually go to the IEC socket manufacturers website and print out the dimensioned drawing of the hole cutout at 1:1 and tape it to the chassis to use as a template. Drill a couple holes to pass the coping saw blade through and cut your hole. Minimum filing required if you take your time with the cut.
Good luck |
| Fs:neutrik Gold Plated Rca Socket Female Chassis - Free Shipping! | YFW | Swap Meet | 0 | 24th August 2008 05:29 AM |
| help soldering ground wire to a Cardas female RCA chassis socket | jarthel | Parts | 4 | 6th March 2007 01:23 PM |
| DAC cutting out | malcontent | Digital Source | 10 | 2nd March 2007 09:19 AM |
| Making a hole for AC socket in a chassis | engels | Tubes / Valves | 32 | 15th February 2007 03:48 PM |
| Not really sure where to put this...but...source for chassis cutting/finishing? | Glowbug | Everything Else | 4 | 15th March 2006 06:37 PM |
| Page generated in 0.08784 seconds (80.88% PHP - 19.12% MySQL) with 11 queries |
