| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Chip Amps Amplifiers based on integrated circuits |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#11 | |
Agreed. Measure it .. about three times. Then get a glass of whiskey and measure it once again .... for good measure :P Do note that a sip of whiskey may help for a steady hand, but a few too much may help for stitches in the local emergency ward. Drill 4 holes carefully in the exact corners of the opening. The IEC sockets are usually square, having the corners already drilled helps with not dremelling too far by accident. Get the metal cutter disk on the dremmel and start the process. Be careful, take it slow. Those disks are very easy to snap. For the love of eveything that is sacred, do use protective glasses. You will, sooner or later, break one of them, especially if the metal is not too thin. They explode in spectacular fashion and fly everywhere at pretty admirable speeds. Also - do not that the bloody thing will get hot, which can be an annoyance when you're cutting aluminium. Once you're done, use a file to smoothen the lines and make everything wide enough for the component to fit. Snap it in and use some hot silicon glue on the inside for good measure. |
#12 |
I do it freehand with a dremel using a standard cutting disk. I have a set of micrometers to measure every once in a while.
If you go slowly and don't get carried away it will may work out. I admit that sometimes they didn't come out perfect!
My DIY audio projects- PartTimeProjects.com. |
#13 |
Aye aye. But if you cut on the inside of the lines you marked the material with, you've got about a half of millimeter error margin. And then you perfect it out with the file.
#14 | |
It's quite possible to cut perfect holes with a cutting disc, with enough practice.
http://mrevil.pwp.blueyonder.co.uk/ |
#15 |
Hmmm, I didn't see those in my store. Those were the type I was looking for, since that's what big metal-cutting devices use. I didn't find them so I assumed they didn't make them for the dremmel.
Other than that - results are usually great. I've had to cut a bajilion holes in wood and steel and aluminum the last few months ( god, casework is so demanding) and nothing has ever turned out better than the square IEC socket holes from the dremmel. It's actually a little spooky how good they got. |
#16 |
Build the chassis using wood, easier to work with and you can make BEAUTIFUL wooden chassis.
If you like lined it with copper sheets, internally. Overall cheaper too. |
#17 |
Yeah, you see, wood can be trickier to work with sometimes. Although some mistakes can be fixed quite easy.
Also - the blasted thing burns if not treated with anything and DIY-product fire-hazard material is ... well .. You've got to be careful. Aesthetics are fine but do take care of the construction and make sure you insulate everything. What if the wood gets wet for some reason and becomes conductive? You also can't earth it so you sacrifice some of the metal chassis benefits. |
#18 |
See this thread -
http://www.diytube.com/phpBB2/viewto...er=asc&start=0 Gyros brand fiber wheels were recommended Specifically, Gyros part # 11-32156 and their mandrel model #80-18100 You can get this as part of a set - http://www.amazon.com/Gyros-Precisio.../dp/B000066B53 |
| Thread Tools | |
| Fs:neutrik Gold Plated Rca Socket Female Chassis - Free Shipping! | YFW | Swap Meet | 0 | 24th August 2008 06:29 AM |
| help soldering ground wire to a Cardas female RCA chassis socket | jarthel | Parts | 4 | 6th March 2007 02:23 PM |
| DAC cutting out | malcontent | Digital Source | 10 | 2nd March 2007 10:19 AM |
| Making a hole for AC socket in a chassis | engels | Tubes / Valves | 32 | 15th February 2007 04:48 PM |
| Not really sure where to put this...but...source for chassis cutting/finishing? | Glowbug | Everything Else | 4 | 15th March 2006 07:37 PM |
| Page generated in 0.19931889 seconds (83.87% PHP - 16.13% MySQL) with 10 queries |
