Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 17th June 2009, 06:53 PM   #1
Default My first Headphone amp build
Hello..
I am a long time lurker with very few posts.
Finally i mastered the energy to get my lazy butt out of the chair and build a headphone amp.
I used a Texas Instruments TPA1517 for the amp.
Below are the results.
It is not fully complete as i have only finished fabricating the board.
The chassis and the works are in order.
Ladies and gentlemen
presenting
HDamp
(Pun intended.)
Hdamp layout
PSU Board
Amp board
The PSU receives its supply from a 10va trafo with 12-0-12 stepped down from 230-0
The 12-0-12 is rectified , and regulated (7815) and filtered
PS: it is my first time building something and that too with SMDs
feedback is appreciated
Old 18th June 2009, 02:53 PM   #2
Does the 7815 not run hot? 24 V AC is quite a lot to produce 15 V DC. And 2 channels with 4 A peak output each are also a lot for a 1 A regulator.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 18th June 2009, 04:35 PM   #3
good, how are sonic results . . .
hey did u made the PCB at home, if yes , can u tell me how you do tinning (silvering) of the PCB.
http://diygainclone.blogspot.com/
Old 18th June 2009, 05:32 PM   #4
@pacificblue
it does
but i m not using a 4 ohms load.
i am using it to drive a 32 ohms headphone load.
the only heat dissipated is the difference between the input voltage and the regulated output.
i am using it with a heatsink, i have just not shown it in the picture
once the chassis is finished i will post updated pics again.
@kuldeep
I have tinned it using lead, 25w soldering iron and a solderwick
the fastest and least cumbersome way to tin it..
Old 18th June 2009, 06:22 PM   #5
hi, can u tell me in detail, i've been looking for such a thing for quite a long. "lead" means u used any solid lead piece along with solder wire?
Old 18th June 2009, 07:02 PM   #6
@kuldeep
no mate.
i used plain , run of the mill solder wire (60-40)
first
apply flux to the entire board.
let the iron become hot.
tin it
not take a small quantity of solder onto it
Let the flux core evaporate( i assume you are using rosin core solder)
now use the iron as a paintbrush and coat the entire board in fast, small strokes
Cover only a small area once
and DO NOT use excess solder.
You are only trying to tin the board not solder anything onto it.
(A small droplet of molten solder can be used to coat a 1 inch x 1 inch copper clad fully.)
Now flux the solder wick
Now use the solderwick as a mop to remove the excess solder,if any, over the tinned tracks.
It is pretty easy mate.
Do one board and you will get the hang of it from the second board itself.
PS : Do search youtube for "tinning"
It will give some helpful results
meanwhile see the video
It is much more useful than a page of writing..
http://www.youtube.com/watch?v=i32f5_0hXQU
Old 18th June 2009, 07:07 PM   #7
thnx, the video is good
Old 18th June 2009, 07:17 PM   #8
this video explains the entire process in detail mate..
give it a look
Old 18th June 2009, 07:18 PM   #9
sorry forgot to add the link..
http://www.youtube.com/watch?v=Wa0aU...eature=related
Thread Tools
Can I build a headphone amp with NE5532 or TL047CN travis Chip Amps 8 22nd April 2009 02:24 AM
Headphone Hub?? baronofhell Everything Else 3 26th May 2007 01:37 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Zen v4 headphone amp Rob M Pass Labs 11 21st May 2003 01:58 AM
Page generated in 0.21543789 seconds (83.50% PHP - 16.50% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
