| Chip Amps Amplifiers based on integrated circuits |
#11 |
Another good preamp route is something like a two channel type: Rocktron Gainiac/Silver Dragon or the newer Seymour Duncan line. Perhaps run a good compressor for the clean channel and A/B.
If your already running power for your chip amp that's a great way to power the tubes enough to get some colour. The above schematic is a beautiful approach. Tube preamps rule for tone that you, the player, can connect with. Go this route if at all possible and ASAP! |
#12 | |
You will get the best tone by far if you go all tube. The power amp stage in a guitar amp really does add color to the sound. Using one tube in the preampis not the same. Look up "firefly" or "high octane" at the ax84.com web site. You can build one of those all tube amps for about $250. |
#13 |
That Edcor company looks great. I see the preamp transformer here:http://www.edcorusa.com/Products/Sho...ct.aspx?ID=598
Still, what would be REALLY nice is that is a toroid form—like the one used in a Lee Jackson Prefect Connection preamp. Even better would be added dual 25Vac as well for our chip. So something like: 175-0-175) at 60mA and 6.3V (3.15-0-3.15) at 2A and 18V+18V at 250VA With all the amp modellers out there this could yield something quite useful ![]() ChrisA~ good point, still I've fine tuned/revoiced a few guitar amps via the preamp out and headphones and got some really nice tones
#14 | |
Edcor will make custom transformers for not much more than the price of their stock units. Call them. All you are asking for is a one more secondary winding on top of a stock unit. one other option is to make a voltage tippler with some caps and diodes from the 6.3 secondary. You don't need all of those amps. The preamp tubes use only 0.3 amps each of the 6.3V so there is plenty of current to support a voltage tippler. And about the sound coming from the preamp vs. the power section. I think the real answer is that it's additive. And it continues with the speaker too. Some of that distortion you hear at high volume is the speaker cone breaking up and no longer acting as a solid, mass but something more flexible |
| Death of Gain Clone | widowmaker | Solid State | 341 | 12th April 2010 10:14 AM |
| Gain clone testing | stcboy | Chip Amps | 3 | 2nd August 2008 04:27 PM |
| Hum from my gain clone when using a preamp | mac-attack | Chip Amps | 19 | 7th April 2006 09:18 AM |
| FS: Gain clone and heatsinks | vsr123 | Swap Meet | 12 | 14th February 2005 04:01 AM |
| What is a Gain Clone exactly? | Lars Clausen | Chip Amps | 33 | 26th November 2003 06:33 PM |
| Page generated in 0.08981 seconds (79.13% PHP - 20.87% MySQL) with 10 queries |
