Old 16th June 2009, 10:18 AM   #11
kenny12 is offline kenny12  Australia
atm i'm just using the amp since i just got it.
the soundcard is an m-audio audiophile,
headphone amp set at 10 gain with very low noise floor when using a audio technica a700 headphone
i plan on using an stepped attenuator as the pre for the amp.
edit: also the noise is def from the amp itself, i've tried with no input with similar noise.
basically i just wanted to know if it was worthwhile ripping out all the eq stuff or is the tda chip generally noisy
Old 28th June 2009, 01:49 PM   #12
sangram is offline sangram  India
The TDA7293/4 are not noisy chips at all.
Nor is the Audiophile, for that matter. I have a Delta66, essentially the same thing, but dead silent into an amp with a 26dB (x20) gain.
I wonder whether the way you have it connected is an issue. Do you have the original 2496 or the USB version? I assume if you have a headphone output it's the USB, then, well, m-Audio floats the cold end of the balanced connection off the chassis ground, it's not a 'real' balanced output.
If you hooked it up with the shield disconnected to an unbalanced input (very likely), you will have a noise fest all the time.
I went crazy trying to troubleshoot this very same issue on my Delta, till I ripped the dock open and found the 'balanced' output was not really so, and I would have to short pin 1 and 3 at the amplifier end, and lose the noise rejection benefit of a real balanced connection, or wire it up without the cold end connected at all, which is what I ended up doing and it's quiet as a kitten right now.
Noise from Ground Zero GZPA1.5000SPL Bertje Car Audio 3 2nd January 2009 12:15 AM
Very Bad Ground Noise - No Music kdhorne73 Car Audio 9 4th August 2008 08:48 PM
DAC Ground Plane Noise Reduction? fastcat95 Digital Source 1 3rd May 2005 06:08 PM
USB noise (noisy ground) Flemming J P Digital Source 5 9th February 2004 03:57 AM
Page generated in 0.06149 seconds (74.03% PHP - 25.97% MySQL) with 10 queries
