Old 14th June 2009, 05:31 AM   #1
Default ESP Integrated Preamp Question
Hello,
I was wondering about building a preamp similar to the layout on the ESP website. It would have 4 inputs including a phono. From the website (see picture) it says I would need the preamp (P88) the phono (P06) and a power supply board (P05).
Wouldn't I need two power supply (P05) boards - one for each the phono and the preamp? If not, how would I wire it up so that both the phono and preamp are getting the 15V input from the power supply?
Another question is would I need one AC wall wart for each power supply? Can I run two power supply boards off one wall wart?
Old 14th June 2009, 07:45 AM   #2
Default Re: ESP Integrated Preamp Question
Trust Rod Elliott on that. One power supply is sufficient.
The answer is so simple and obvious that I am reluctant to give it. You should get yourself acquainted at least with the basics before you start to build anything. Find out, what parallel and series connections are and then, which is the right solution in this case and why.
Hint 1: How do you connect appliances in your household to the power grid?
Hint 2: The answer 'Plugging them in' is not the solution.
Depends on the wall wart. How much power do two power supplies consume worst case? Compare that to the wall-wart's power rating.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Integrated AMP with PGA 2311 preamp kpero Chip Amps 5 26th April 2009 08:05 PM
Passive preamp before an integrated (?) amp 454Casull Solid State 4 15th April 2009 07:08 AM
bypassing preamp board in integrated amp woodturner-fran Tubes / Valves 1 22nd October 2006 12:35 AM
integrated amp as mic preamp? Ang Instruments and Amps 1 21st July 2006 03:57 AM
Integrated CD Player/Preamp mcai7et2 Digital Source 1 10th December 2003 11:29 AM
Page generated in 0.07581 seconds (64.68% PHP - 35.32% MySQL) with 11 queries
