OPA548 pcb layout - for your enjoyment
Old 30th April 2003, 11:54 PM   #1
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Default OPA548 pcb layout - for your enjoyment
Hi Folks
Well, I have been busy building 10 channels of OPA548 gainclone for a friend over the past week or so, and as I had to make so many I made a single sided pcb layout to make it easier!
So, for all those that are interested the PCB layout is below, scale is based on 1" squares, so it should by easy to rescale to whatever output you want. The circuit is based on Thorsten's new ideas, and is not minimal! As I live in an area of huge RF interference from two of the biggest TV/Radio transmitters in the UK, I have given up on the minimal designs, but if you wish you could just use wire links instead of some components. You may also need to slightly adapt the design depending on the size of your components.
The circuit layout is completely hum free and stable, with no oscillations I can detect on my 5meg scope.
Note, the E/S pin(9) is snipped off the IC before installation!
Have fun
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 2nd May 2003, 11:53 AM   #2
carlosfm is offline carlosfm  Portugal
Banned
Default multi-turn pot
Al,
At least with an LM3875 I had around -10mv of DC offset with that 18k resistor.
I changed it with a 50k multi-turn pot, and now I have between 0.0 and 0.1 mv DC offset.
Beautiful.
Old 2nd May 2003, 12:13 PM   #3
pinkmouse's Avatar
Hi Carlos
The dc offset on all my amps was around +8 to +10mV. Your idea of using the multiturn pot is a good one, I may give it a try at some point.
These amps were configured as two 5 ways for a friends 2 HT setups, one in his lounge and one in his bedroom to replace the mixture of cheap amps he was using. They were all built in 2U rack cases, and were nothing to look at really, which is why I took no photos.
I was also playing with my stereo OPA548 the other day, that I modded to the same circuit for testing, and got some interesting results when I fed it square waves, I may post these photos later in a different thread for others to look at and discuss.
Old 2nd May 2003, 12:55 PM   #4
Banned
Just try it, Al.
You won't need to modify the circuit board.
It's not very important actualy the value of the DC offset (8 to 10 mv is fine).
But on a stereo amp it's good to have both channels with exactly the same value.
Differences kill soundstage.
Old 15th May 2003, 12:40 AM   #5
popes is offline popes  South Korea
Send a message via MSN to popes
Wink i try some modify..
i remove input capacitor
and i'll try 3 parallel bridge 548 gainclone.
this PCB use for bridge mode.
Kurt
Old 15th May 2003, 12:44 AM   #6
Default next PCB
3 parallel PCB
Kurt
Old 15th May 2003, 07:45 AM   #7
pinkmouse's Avatar
Hi Popes
Looking good! Certainly much quicker and more economical to home etch
The only problem you will have is with the Earths. The three up board will definately need the ground plane splitting so you have one per amp, and you may need to split the signal earths to make a star ground as I did on my version. The only way to find out is to build one!
Good luck
Old 15th May 2003, 04:42 PM   #8
Banned
Yes, after building one you may find you need to fine-tune the circuit.
The way to go first is doing it in breadboard, like I did.
Old 18th May 2003, 03:58 AM   #9
Default my 548 pic.
i'm aready make 548clone
here is my..
inverted
R=caddok 10K and IRC 200K
C=10uF MKP
power supply is two single output SMPS 20V 5AMP.
Kurt
Old 18th May 2003, 03:59 AM   #10
Default more pic
there is no....Hummmmmm
Kurt
OPA548 pcb layout - for your enjoymentHide this!Advertise here!
OPA548 and shutdown kafka Chip Amps 9 5th September 2004 04:26 PM
OPA548 Supply? Devil_H@ck Parts 5 13th June 2004 01:47 PM
Is a subwoofer needed for musical enjoyment?? dont argue folks(discussion) Andre Baptiste Subwoofers 52 19th March 2004 11:47 AM
my opa548 headclone for AKG-K1000 digi01 Chip Amps 14 24th February 2004 07:19 AM
GainClone with OPA548 - impressions Cradle22 Chip Amps 3 12th March 2003 05:04 PM
