| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
I am putting together (albeit very slowly) a headphone amp based on this design (http://www.headwize.com/projects/sho...e1_add_prj.htm) with an added CCS output stage, to go inside my passive pre for my LM3875 dual mono Gainclone.
I have aquired a Low noise preamp kit from Maplins (UK) based around an NE5532 dual opamp http://www.maplin.co.uk/Module.aspx?ModuleNo=220053. My question is, would it be possible to impliment this preamp into the Szekeres design? Would it just be a case of connecting the output of the op-amp to the the input of the MOSFET amp? Chris. |
#2 |
your Maplin link takes me to the front page.
Why do you need a preamp before the headamp? What's wrong with feeding your signal straight to the volume pot?
regards Andrew T. |
#3 |
It was just a general question. It is not my intention to fit it, I was just exploring the possibilites. A bit of experimentation helps the learning process
.Chris. |
| Thread Tools | |
| Szekeres with CCS NFB? | kacernator | Solid State | 9 | 4th August 2009 07:58 AM |
| Can I build a headphone amp with NE5532 or TL047CN | travis | Chip Amps | 8 | 22nd April 2009 02:24 AM |
| NE5532 suitable for headphone amp ??? | Bernhard | Parts | 1 | 29th February 2004 12:50 AM |
| DIY Power supply for a Szekeres headphone amp | Bricolo | Solid State | 93 | 30th November 2002 06:58 PM |
| Some questions about the Szekeres headphone amp: | Bricolo | Solid State | 16 | 25th November 2002 08:39 PM |
| Page generated in 0.11704993 seconds (74.53% PHP - 25.47% MySQL) with 10 queries |
