| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hey!
Please forgive the novice-ness of my question, I hope it hasn't been covered too well in earlier posts. I've given up on the search function. Anyhow, I've played around with unity gain buffers for my guitar signal, and I've built a couple of these: http://www.generalguitargadgets.com/..._ic_buffer.pdf ...with quite convincing results. Anyway, I would like to modify it so that it inverts the signal, in order to couple one regular and an inverter into a balancing circuit. Question 1: How is this done? I'm suspecting it to be something as easy as switching pin 2 and 3 on the TL071, but I need it confirmed. Question 2: If I make a Direct Injection box with a such circuit, will it be a miserable fail, or will it work quite well? I guess this excludes any sort of ground lift. Regards, Emil |
#2 |
this should help -> http://www.facstaff.bucknell.edu/mas...Note2Gain.html
if you look at the formula given you want the resistors to give you 1. I.e Vout = - Vin R0 / R1 so R0/R1 = 1 another example -> http://sound.westhost.com/project51.htm |
| Thread Tools | |
| pse help, unity µ triode as a phase inverter | oldeurope | Tubes / Valves | 64 | 18th September 2008 02:56 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 02:30 PM |
| Unity Gain (AV=1) Zen Amp | LS | Pass Labs | 2 | 16th September 2004 05:40 AM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 02:47 AM |
| Page generated in 0.19074798 seconds (30.87% PHP - 69.13% MySQL) with 10 queries |
