| Chip Amps Amplifiers based on integrated circuits |
Hi im looking to build a chip amp based on Mark Hennessy's micro amp, i just got a 225va transformer but its got 2 x 40v secondaries, is this too much voltage for an amp based on the LM4780?
or is there a way round this? |
#2 |
Need to know more about the transformer: does it have single or dual primaries? Are the secondary windings center-tapped?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Absolute maximum voltage for the LM4780 is ±42V.
Your 40-0-40 transformer will have a no-load voltage of about 58V~59V (depends on the regulation factor of the transformer). "is there a way round this?" New transformer.
Candidates for the Darwin Award should not read this author. |
#4 |
build a Leach Lo Tim.
He has optimised the design for an 80Vac Centre tapped transformer. The 225VA is just about perfect for a 150W into 8ohm monoblock.
regards Andrew T. |
#5 |
Hi leadbelly thanks for your quick reply, it has 2 x 110v primaries and the secondaries are 40 - 0 - 40v
the transformer hasnt yet been delivered there is a picture here: http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=140323887232 thanks in advanced |
#6 |
that'll teach me to buy something thats cheap rather than what i actually need!! im sure ill use it for something in the future
#7 |
Now I'm confused by others answers. Won't there be a VR, somewhere between the secondaries and the amp? Why not just regulate to whatever voltage you need? Having a higher voltage relieves you of worrying about using a low-dropout reg.
#8 | |
regards Andrew T. |
#9 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#10 |
The pictures on ebay show this is a 40 / 40 volt not really a 40-0-40, though it COULD be connected that way.
The good news is that since you have two separate 40volt windings you can regulate the output using two positive regulator chips. 40v AC to the rectifier will give you about 53-58 volts under load which is too much for the popular LM338 regulator chip. There are other voltage regulator chips that can be used, but dropping the 56 volt output down to 35 volts will generate lots of heat (regulator will need a big heat sink.) Another trick would be to reduce the voltage to the primary of the transformer but since this one is potted you can't add additional turns to the primary. You can connect the output of a smaller transformer in series with the primary to reduce the input voltage though. Since this transformer has a dual primary if you connect the windings in series and run the transformer off 120v you will end up with a 20-0-20 volt secondary (half) which will give you 28 vdc. This is perfect for 68 watts into 4 ohms or 30w into 8 ohms. Also 120w into 8 ohms with two amps bridged. |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 09:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 06:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 11:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 09:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 05:36 AM |
| Page generated in 0.09992 seconds (81.39% PHP - 18.61% MySQL) with 10 queries |
