| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Chip Amps Amplifiers based on integrated circuits |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#11 |
If you want to use a voltage regulator, you can use an LM317 with a handful of external components to create a high-voltage regulator (National Semiconductor App Note (pdf)). You'll probably need more current than this can provide, but that's easy with a bipolar pass transistor (good ol' 2N3055 comes to mind).
Just remember that your voltage regulator needs to be able to handle sqrt(2)*VAC, where VAC is the no-load voltage of the transformer at maximum AC input voltage. Tom |
#12 | |
If you buy a new transformer, it makes sense to buy one with the correct output voltage for the amplifier and use the 2x40 V for a different project.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#13 | |
Is there any reason this is a bad idea? |
#14 | |
#15 | |
The VA rating of the transformer core remains the same even if you half the primary voltage. BUT, the current rating of the primary and secondary windings are based on the VA rating at the rated voltage. This means that the VA rating of the transformer is reduced to about half of it's original rating at half the input voltage. You can probably pull a little more than that though, because you won't be saturating the core (which can handle the original VA rating). The limit will be due to heating of the primary and secondary windings as they are asked to handle more than their original current ratings. Monitor the output voltage of the secondary under load, and limit the current to that drawn when the output voltage drops to one half the rated output voltage (20 volts). |
#16 |
Ok, now I get it. I was having a slow moment
#17 | |
I guess I'll just continue to read and learn.
#18 |
Thanks for your input guys, think ill stick with keeping the amp simple, ill bite the bullet and get the right transformer
| Thread Tools | |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 09:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 06:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 11:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 09:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 05:36 AM |
| Page generated in 0.22005200 seconds (77.63% PHP - 22.37% MySQL) with 10 queries |
