| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Chip Amps Amplifiers based on integrated circuits |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
I would be making LM3886 based Power Amplifier, Stereo , and 5.1ch amp. The design will be beased on carlosfm, Application Notes, and other circuit. Also, Many DIY'ers in India are not able to source PCB for carlosfm project AD815 pre with LM3886. I need consent from authors and moderators, If I can make PCB and post GB for Indian DIY'ers Thanks suds
~suds~ |
#2 |
Use the e-mail button and PM the authors. You cannot expect them to follow all threads 24/7 and find yours.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Thanks! will do it.
~suds~ |
#4 |
Electrons are yellow
Alternative to AD815 is the TPA6120a, more or less the same IC and THS6012 is identical to TPA6120 except for tighter specs.
/Per-Anders (my first name) or P-A as my friends call me BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb, checking interest Sign up HERE Rectifier bridge RFB03 Group Buy Round 2, checking interest Sign up HERE |
#5 | |
#6 |
Only they don't sound anything like the AD815 in my experience.
#7 |
Did each IC have optimal working conditions?
Sometimes when you compare, one of the test object works good but the other one maybe needs a different environment. As for power stage to drive headphones, the TPA6120 is excellent.
#8 |
analog sa - are you saying the TPA6120A and THS6012 sound better or worse than the AD815? I've read lots of stuff about the 815. Is it really that good?
#9 |
My AD815 pre-amp PCB layout. .
based on carlosfm ad815 pre. ad815 smd version is used here..
~suds~ |
#10 | |
Don't know about optimal but they were identical - same Jung regulators, raw dc and attenuator. And i only tried the TPA6120. No idea how good either is as a headphone amp as i only tried them in a line stage comparing the sound of an active stage to a bypass. The AD815 is really amazingly transparent for an opamp but ultimately did not entice me to use it as a line stage in the long term. I guess it's a quiestion of taste, priorities and expectations of what a line stage should achieve. For almost a year i used and enjoyed a Pass Aleph 1.0 clone which is nowhere near as transparent and currently use a choke loaded 5687 common cathode stage which is simply in a different class. |
| Thread Tools | |
| cheap LM3886 amps for aussie | ttan98 | Chip Amps | 9 | 27th March 2008 10:19 AM |
| lm3886 vs receiver amps | nvrgdenuf | Chip Amps | 3 | 17th February 2007 07:40 AM |
| the guy who did a P2P lm3886 w/ ad815 | frdchang | Chip Amps | 4 | 3rd December 2006 11:15 PM |
| MY finished LM3886 amps | filholder | Chip Amps | 21 | 12th April 2005 06:55 PM |
| WTB B4 and UV4 tube bases | bcherry | Swap Meet | 0 | 26th September 2003 06:22 AM |
| Page generated in 0.46003199 seconds (43.47% PHP - 56.53% MySQL) with 11 queries |
