Old 3rd June 2009, 07:26 PM   #1
NSLogan is offline NSLogan  United States
Default Beginner PSU question - parallel rating
Ok, so i'm reading the tutorial about PSU's posted at the top of the forum (gainclone psu) and am currently looking for a transformer on digikey. The problem is (being a beginner) i'm not quite sure what i'm supposed to be looking for. There are two options on output (parallel and series, i know what those are and what's different between them) and then an option on maximum power (VA). My problem is with the type of output, it's written as: # VAC @ # A. I know that the output then will be in VAC but i'm not sure what the amperage rating means. Is that the maximum load the transformer can support?
Here's basically what i'm trying to accomplish:
-I have two 4 ohm 15 watt speakers i want to run with an lm1876 (one for each channel of stereo input)
-The tutorial on PSU's suggests a 12VAC secondary voltage so i'm matching that on the transformer.
Now: the lm1876 will pull 22W max on each channel so 44W max overall. Does that mean the amperage of the transformer must be high enough to have a maximum power of greater than or equal to 44W?
Basically, would i need a transformer (if i'm in parallel on output) that outputs 12VAC @ 3.67A or more?
Old 4th June 2009, 09:30 PM   #2
Default Re: Beginner PSU question - parallel rating
Yes. The nominal voltage is given at that current. Most transformers can support more than the nominal power rating, but the output voltage will drop and as the current draw passes above the nominal current to make up for that, they will run into saturation. That means, what comes out of the secondaries are not clean sine waves anymore. The output is distorted. Those distortions pass through the power supply into the amplifier and will audibly affect its performance. And the transformer will run hot.
Absolutely right, except for the parallel part. The LM1876 needs ±10 V or more. You have the choice to use a single supply, meaning those 12 V secondaries would have to be connected in series or to use a split power supply, meaning each secondary feeds one half of the split supply. Parallel connection would leave you with 12 VAC -> ~16VDC at idle and ~14VDC loaded and the LM1876's undervoltage protection would probably not let you listen to any music.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Beginner question/s OB tjthe1st Multi-Way 2 20th December 2007 05:09 AM
ZV7R: Question from beginner salam-kaz Pass Labs 47 12th December 2006 02:14 AM
beginner amp choice question baggystevo82 Tubes / Valves 4 29th December 2003 08:22 PM
Beginner seeks help with “the usual question” Tim Buchanan Multi-Way 10 27th January 2002 10:35 AM
Page generated in 0.06307 seconds (80.19% PHP - 19.81% MySQL) with 10 queries
