Old 3rd June 2009, 04:17 AM   #1
riaz is offline riaz  Philippines
Question Lm3886 Help!
Hello all,
I need help in troubleshooting my amp please, kindly help me find out what's wrong with my amp because when i tested it to a speaker the sound that comes out is attenuated and then disappears and reappears back again after a short while. This action gets repeated over and over. What should i be aware of guys?
Equipment used:
Rotel ra-02 as preamp
LM3386TF Amp is based on "A minimalistic chip amplifier" by Mick Feuerbacher http://tinyurl.com/3resamp
Tested to a single 4 ohm woofer
Power supply: 220v ac/ 18vdc, bridge rectifier, and 2 cans of 15,000 uf caps
Old 3rd June 2009, 08:42 AM   #2
Default Re: Lm3886 Help!
DC at the output, heatsinking, shorts and bad solder joints.
If you've always done it like that, then it's probably wrong. (Henry Ford)
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 07:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 06:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 12:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.06510 seconds (70.68% PHP - 29.32% MySQL) with 10 queries
