Old 3rd June 2009, 03:27 AM   #1
pingu is offline pingu  United Kingdom
Default lm3886 design
I'm using a 2x 28v transformer salvaged from an old arcam alpha.
Is it Ok for me to use this with the typical application diagram on the lm3886 data sheet? I Just want to get this up and running ASAP and prehaps tweek it later. So as long as using this circuit isn't hi fi blasphemy ill go right ahead!
Also have some more noob questions-
Does it matter which way round i place the inductor?
Is the Lm3886 stereo capable?
Tim
Old 3rd June 2009, 04:04 AM   #2
ttan98 is offline ttan98  Australia
Using 28V ac is at the upper limit of operation for LM3886, it should work OK. Use adequate heatsink, CPU heatsink or preferably larger is adequate.
BTW I use 24V ac, the CPU heatsink is not even hot.
Old 3rd June 2009, 10:16 AM   #3
Default Re: lm3886 design
You should use 8 Ohm speakers with that voltage.
Read the datasheet. It explains, what you should do and why. Relax and take your time. Putting things together in a hurry is usually not a good way to work, especially for a first project.
Can you detect any difference between both ends of the inductor?
If you use two of them.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 3rd June 2009, 03:27 PM   #4
ok im looking at the 'typical application' on the lm3886 data sheet:
http://www.google.co.uk/url?sa=t&sou...xVsZsIPWMxhvVg
will this circuit work with my power supply?
Old 3rd June 2009, 03:42 PM   #5
have you read the note at the bottom of Fig1?
I can count one optional component shown and seven other optional components that are missing.
The "optional components" are compulsory until you have sufficient design and assembly expertise and test equipment to prove to yourself that the circuit can operate reliably with a range of output transducers, without destroying itself and/or plain sounding bad.
regards Andrew T.
Old 4th June 2009, 02:03 PM   #6
Keep in mind that CPU heatsinks are not designed for use without a fan (the fins are too close together for convection cooling).
Old 4th June 2009, 04:14 PM   #7
not really, I use LM3875 and LM3886 mounted on cpu heatsink(*) without fan turned on on some occasions without problems. I even powered both of them using 34Vdc.
If you use low load(=<4ohm) and play at loud level then CPU fan should be turned on.
* I use PIII or PIV heatsink and I pay about $5 each, cheap and it works. I mount even 2*LM3886 on a single heatsink, this time I turn on the fan.
Old 4th June 2009, 06:49 PM   #8
that's most odd, uses a fanned sink as it's supposed to be used when required to dissipate some heat. Funny decision that.
regards Andrew T.
Old 4th June 2009, 11:57 PM   #9
Not so if the amp is lightly loaded ie if playing at low level. The amp never gets hot. I built 2 amp one with fan turned on and the other with fan left off.
You must remember this is a hobby and there is no need to spend unnecessary money if you can get away with it. I am not building a Rolls Royce equivalent of an amp.
The left over money can be used for other projects.
Old 5th June 2009, 12:06 AM   #10
garak is offline garak  United States
From the pictures I've seen of heatsinks used for LM3886 amps, and the resulting reports of how warm the heatsinks feel, I get the feeling that a CPU heatsink (designed for use with a fan) would be just fine, even if it's operating outside of its intended use and convection is lacking. It's still MUCH less heat than a CPU puts out.
I'm planning on using some Athlon heat sinks that I got for $2 each.
yet another lm3886 design geekysuavo Chip Amps 0 31st July 2008 11:18 PM
8 X LM3886 design sought gary h Chip Amps 18 25th January 2008 02:36 PM
Datasheet Lm3886 Design and others. samsagaz Chip Amps 1 29th December 2007 02:53 AM
LM3886 : which design ? Volta Chip Amps 10 22nd April 2006 07:02 PM
Design from scratch (LM3886) VEC7OR Chip Amps 25 30th September 2004 02:16 PM
Page generated in 0.12177 seconds (80.13% PHP - 19.87% MySQL) with 10 queries
