| Chip Amps Amplifiers based on integrated circuits |
#11 |
The trouble is, most manufacturers seem to think that publishing the thermal data of CPU heatsinks is a breach of etiquette, so you hardly ever know, what you get. Some DIYers seem to think the same about calculating heatsink sizes and that Trial-&-Error is the only way to go.
What little thermal data is available indicates that CPU heatsinks are indeed in a reasonable range to fit a chipamp. Most show 2-4 K/W without a fan and 0,5-1,5 K/W with fan. But again, you hardly ever know, what you get, and therefore you absolutely should provide the fan.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#12 | |
I for one has a different policy, I don't like to over design, if the heatsink is not even warm when amplifier is idle and I am using easy load and don't play very loud, should turn on the fan permanently? Ans is NO. |
#13 | |
If one wants to design then one must define the specification that must be met. Any design that meets the specification is a good design. If the specification is lacking then that does not make for a bad design, it indicates the lack of foresight on the part of the team defining the specification. There is no need to be conservative nor to over design nor risk unreliability. It all should be defined.
regards Andrew T. |
#14 | |
#15 | |
This is true. Parameters meant as a base guide on every things we do but the implementation is up to the builder to decide as long as safety precaution taken for consideration even not 100% as stated to the manual....remember this is a hobby where we spends time and effort on something that we passion about and this is how diyers get creative...according to their pockets... IMHO.... |
#16 | |
regards Andrew T. |
| yet another lm3886 design | geekysuavo | Chip Amps | 0 | 31st July 2008 10:18 PM |
| 8 X LM3886 design sought | gary h | Chip Amps | 18 | 25th January 2008 01:36 PM |
| Datasheet Lm3886 Design and others. | samsagaz | Chip Amps | 1 | 29th December 2007 01:53 AM |
| LM3886 : which design ? | Volta | Chip Amps | 10 | 22nd April 2006 06:02 PM |
| Design from scratch (LM3886) | VEC7OR | Chip Amps | 25 | 30th September 2004 01:16 PM |
| Page generated in 0.08526 seconds (76.22% PHP - 23.78% MySQL) with 10 queries |
