Old 31st May 2009, 10:09 PM   #1
Default LM3886 - Capacitors Between V+ V- and Gnd
Hi guys, i read some tiomes that an cap are used between these pins under the LM3886 IC, wich is the purpose of that?
Is better to it directly to the IC Pins? or just can be placed in the PCB?
these are the Cap described in the Datasheet as Cs, Ca?
Old 1st June 2009, 09:41 PM   #2
As the datasheet of LM3886 explains - 0.1uF caps must be placed as close as possible to the IC. This is in order to minimize inductance of traces which most likely causes an oscillations.
Old 2nd June 2009, 01:33 AM   #3
Oh, thanks too much for your support i didnt found that in the datashet
So looks like place it under the chip will be the best way
Help identyfing capacitors on lm3886 briangt Mr. Julius Chip Amps 6 15th January 2009 07:45 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.06144 seconds (78.39% PHP - 21.61% MySQL) with 10 queries
