LM3886 Mute Disable
LM3886 Mute Disable
Old 27th January 2013, 01:49 PM   #11
surya0562 is offline surya0562  India
i am making lm3886 amplifier i got the circuit & pcb file from http://http://www.eeweb.com/project/...lifier-project i made same to same as shown but on the other hand diy audio user's circuit are some different. so i am in confusion, plz help i am beginner in diy. plz check the circuit and pcb file that they are right or wrong.
Old 27th January 2013, 01:54 PM   #12
i ordered two LM3886TF chip but i found LM3886T chip so i mount them on different Pentium3 heatsink connected with wires. will this trick work? or not. plz comment Click the image to open in full size.
Old 27th January 2013, 10:54 PM   #13
Bloodmist is offline Bloodmist  Romania
Send a message via Yahoo to Bloodmist
Be sure a too low resistor will destroy your LM. I almost did that by miscalculating. Luckily the power supply shut down. But don't go below say 4K you should be fine.
Old 27th January 2013, 11:32 PM   #14
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I'd always use mica and grease, or what you are "saving" now will later complicate your mounting in a chassis.
And personally don't trust fans very much, prefer "real" heatsinks or at least a vertical aluminum plate, 20cm wide x 10cm high , 2 or 3 mm thick.
Old 28th January 2013, 04:47 AM   #15
thanks for your advise, can you check the pcb layout and schematic. I have a doubt something about circuit.
Old 28th January 2013, 05:05 AM   #16
JMFahey's Avatar
Can't speak for the PCB.
As of the schematic, I can't understand why that RC network is used in feedback instead of a simple 22K resistor.
LM3886 Mute DisableHide this!Advertise here!
lm3886 no mute rtill Chip Amps 21 29th August 2009 05:43 AM
[LM3886] Best resistor value for mute ? XELB Chip Amps 50 16th November 2005 09:57 PM
Nakamichi mute section disable hiwiho Digital Source 0 5th October 2004 10:36 PM
LM3886 Mute richie00boy Chip Amps 6 18th August 2004 11:26 AM
lm3886 mute LED blabley Solid State 1 30th May 2002 05:51 AM
