single-supply LM3875 design not working :(
Good morning, everyone---
I've designed two versions of a single-supply powered 3875TF setup, and have had no luck getting the chip to output sound.
The power supply outputs a DC voltage when AC is applied to it, with little if any AC at the outputs (haven't looked at the signal with a scope though, so take that as you wish).
Here is a picture of the reference design for a single-supply setup:
I've used this same setup with two exceptions:
-didn't use any of the optional/starred parts
-I used a 56k resistor in place of the 75k resistor because I had one around
Cap values are as stated in the reference design, with a Cs value of 100uF
Here are a few pics of my implementation, power supply first:
I'd appreciate any help you guys can provide! Thanks again.
