GC Speaker Cable (split from NJAGC) - diyAudio
Old 23rd April 2003, 05:29 PM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
i have two power suplys, one is +/- 15v with 33000uf and the other is 35v with 2200uf, which power supply would be better with which amp?
How much trouble would it be to try both?
what sort if speaker cable is best suited to gainclones? solid core or stranded cable?
So far, I have found the best results with a flat-braided OFC with a 1.5mm2 cross section. Speaker cables do seem to make more of a difference on the Gainclone than on other amps I have played around with!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 23rd April 2003, 08:22 PM   #2
Matttcattt's Avatar
not much
what configuration of cat5 cable should i use? 1 pair per speaker? or all pair wired together?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 23rd April 2003, 08:48 PM   #3
Nuuk's Avatar
I don't have experience of Cat 5 but I would suggest starting with one pair and then maybe trying adding pairs.
Old 23rd April 2003, 10:32 PM   #4
I use 3 runs of cat5 solid core braided together per speaker.
as in the Full Frequency Range Cable design at tnt-audio
FFRC
havent tried it with my gainclone yet. but with my old amp it was a definate improvement over crapola gale 79 strand.
Old 24th April 2003, 11:52 AM   #5
Matttcattt's Avatar
FFRC
ill try both
Old 25th April 2003, 07:29 AM   #6
2Bak is offline 2Bak  Denmark
Default FFRC
Mattcatt, just to inform you that I had problems with the FFRC cable on my GC.
See post http://www.diyaudio.com/forums/showt...858#post158858
..and forward.
Maybe you have better luck though...
/Jan
Old 25th April 2003, 03:27 PM   #7
Matttcattt's Avatar
Default Re: FFRC
..and forward.
/Jan
i saw that post, how many pairs per speaker? i tried one speaker with a cable make with 6 pairs wired together and it worked fine, loads of bass too
Old 25th April 2003, 06:25 PM   #8
Default Re: Re: FFRC
Three cat5 cables braided. Each cat5 has eight twisted pairs. That makes twelve twisted pairs per + and -
/Jan
Old 25th April 2003, 07:42 PM   #9
Philo is offline Philo  United States
Oops, Jan. CAT5e is 8 wires or 4 twisted pairs. That would be 12 wires or 6 pair per speaker cable. Did you keep the pairs together and braid them?
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 26th April 2003, 05:28 AM   #10
Sorry, you are right. 4 twisted pairs in each cat 5 cable. That makes 12 twisted pairs for 3 braided cat 5s, off course.
I separeted the pairs and braided all dark wires (12 total) for plus and light wires (12 total) for minus.
/Jan
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 07:42 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
Cable directionality (split from distortion) mrfeedback Everything Else 29 27th March 2004 12:00 PM
Beer and Wine (split from Cable Directionality) SY The Lounge 8 28th October 2003 01:56 AM
Copyright 1999-2017 diyAudio
