| Chip Amps Amplifiers based on integrated circuits |
#21 | ||
At idle the IC withstands ±47 V. When loaded the voltage will sag to much less than the permitted 42 V DC. So 30 V AC is safe with high enough impedance speakers. Quote:
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#22 | ||
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#23 | |
#24 |
The app note is a bit contradictive. The recommend max +- 37 VDC but thet have a 2 x 30 VACrms transformer.
#25 |
Halo6,
From experience I will say that a transformer with 20-22 volts will make you much happier in the long run. If you read the original thread and the information at Shine7.com you will note that Alexw88 makes several statements regarding the heat output from this design. I used 625va 25-0-25 transformers in my first BPA 300 amp and it gets hot as hell. Like Peranders said a few extra volts at the mains and you are adding still more heat. I am speaking from past experience. The 25+ volt trannies will work you just do not need them. The LM3886 transistors, of which there are only 3 per side, do not offer a tremendous amount of surface area for cooling. Most 300 watt amps have twice as many output devices for this power level. You are buying very nice quality components from what I have read just do not make the "more volts is better mistake" This little chipamp has plenty of grunt with 28-30 volt rails. It is a balanced/bridged configuration which means the speakers see 4 times the output as conventional power and a ground speaker connections. Tad |
#26 | |
http://www.antekinc.com/AN-8420.pdf |
#27 |
tryonziess, you have a good point that the LM3886 sees only 4 ohms and this will make the use of 30 VAC even more wasted.
#28 |
Those antek transformers are a very good deal. I have bought about 10 of them and had no trouble to date. They have really good service and the item usually arrives in 3 days.
Another option is to use two completely separate power supplies. One for each channel. You then can buy a couple of 500 or 625 va units and have superior separation. They come with auxiliary windings for controlling relays or whatever. Nice little option. Have you explored the possiblity of bending the LM3886 leads straight out and mounting parallel with the pcb. I did this and it worked out just fine. No 90 degree elbow to cause layout problems. Just mount everything to the heatsink, nice and flat. You can even run the legs up from the bottom to allow for the standoffs. You then can solder in the small caps on the top. It looks real neat. Tad |
#29 | |||
The BPA application takes those ICs to their limits, therefore it takes accuracy to implement it. And for the same reason it makes little sense to build it, if you do not really want to take the application to its limits. You don't need the additional 6 dB? So build a single chip amplifier instead. Quote:
#30 |
Awesome! This thread is getting some great feedback. I will tone down the trafo to a 20-22 VAC... I rarely drive my speakers that loud anyway...
| Newb planning to build a Valve Amp | ValveAmpDubai | Introductions | 3 | 9th March 2009 09:57 PM |
| My SE KT-88 Build thread | athos56 | Tubes / Valves | 13 | 21st December 2008 06:16 AM |
| newb build; budget floorstander in UK | matteroftaste | Multi-Way | 11 | 8th May 2007 08:36 AM |
| The ESL Build Thread | BillH | Planars & Exotics | 172 | 8th November 2006 09:01 PM |
| Need DIY perspective on build or purchase decision | thayerg | Multi-Way | 2 | 2nd March 2005 06:01 PM |
| Page generated in 0.11665 seconds (82.99% PHP - 17.01% MySQL) with 11 queries |
