| Chip Amps Amplifiers based on integrated circuits |
I was ready to buy the Alps motorized pot (has to be motorized) for a LM3875 gainclone when I came across 25K TDK which costs twice as much:
TKD Potentiometers: Conductive plastic element CP2511 model attenuators and balance controls, 25mm square by 27mm deep with 9mm threaded bushing mount, solder lugs, no-detents, log taper 10K, 25K, 50K, 100K, 250K, 500K… $72.00/stereo $44.00/mono $76.00/balance (no 500K) $85.00/10K, 25K, 50K, 100K motorized 1) Is "conductive plastic" very good quality? 2) Is log better than linear taper. 3) Would this be better than Alps or PEC? So as not to put up too many threads, what would be an adequate soldering iron (under $50.00) / solder for the remote control kit I: Remote 1 kit am building? Thanks |
#2 |
While I"m no expert in Pots I can tell you that the best pots are conductive Plastic .... and for Volume controll a Logorythmic pot would be best , and Liner pot would be better for say a tone controll .....
Cheers |
#3 |
Thanks Minion.
#4 |
Hi chuck55,
I wish I had a chance to give the TKD's a try, but here in Germany these pots are available at Thel Audio only, and the motorized version costs more than 4 times (!) as much as a motorized Alps blue pot. So I went for the Alps pot (have done this serveral times), and this is a very good pot for the money! I guess it's compareable to the noble pots Peter Daniel uses in his integrated GainClones. For volume adjustment I would always use log version, either 10k, 25k or 50k, depending on your source/amps output/input impedance. Regards - martin |
#5 |
Just get a regular one and attach a stepper motor to it.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
| Alps 27mm pots | roger_dodger | Swap Meet | 0 | 8th April 2005 07:37 AM |
| Alps pots vs. TKD pots? TKD worth the extra$$? | G | Tubes / Valves | 11 | 17th August 2004 05:33 AM |
| WTB:alps motor pots | sma | Swap Meet | 0 | 11th February 2004 05:09 AM |
| control the 50k alps pots | sma | Everything Else | 1 | 17th December 2003 06:13 PM |
| Alps pots in the UK? | Kram | Parts | 4 | 18th March 2003 09:15 PM |
| Page generated in 0.10415 seconds (75.00% PHP - 25.00% MySQL) with 10 queries |
