| Chip Amps Amplifiers based on integrated circuits |
Hi everyone,
I've taken apart my 5.1 PC creative inspire p5800 ( not exactly audiophile but ok for 100$ ) in order to do some tweaking ( i've recently got a audiotrak prodigy 7.1 hifi soundcard so i thought that some upgrading of the speaker system was in order ). While I was studying the pcb ( nothing spectacular : two tda8947j amps, a few opamps two volume control ICs and a jrc 4558 as the headphone amp ) I've noticed something strange : the rear left output plug is wired in reverse phase to the rest of the outputs ( they are all RCA plugs soldered to the pcb so this is done intentional by the manufacturer and not a manufacturing mistake - and the front and rear speakers are not marked , any of the four speakers can be used with any rear or front output ).I was wondering if anybody knows if there is a reason behind this "mistake". best regards Paul |
#2 |
I've done some more research (googling mostly
)and aparently having the rear speakers in oposite phase makes the soudstage wider ( based on the research done with the passive haffler matrix ).
#3 |
adding the out of phase rear speakers to a two channel Stereo signal was quite normal. 5.1 is a dedicated 6 channel sound system. It does not need a matrix system to generate any special effects.
regards Andrew T. |
#4 |
Hi Andrew,
I think you are right, but my guess is that Creative tried to make a fairly cheap and "lo-fi" system sound better ( they do-it whith their sondcards - a good example is the x-fi cards ''crystaliser'' ). I was just wondering if it's worth modifing the pcb so the rear speakers are in phase; I only use the system for movies and ocassional gaming. Paul |
| Output Configuration | aged one | Solid State | 15 | 25th May 2010 11:15 PM |
| Output impedance for non published PP configuration | avincenty | Tubes / Valves | 18 | 1st March 2008 05:42 PM |
| Why Nakamichi use this configuration of output transistor | ostie01 | Solid State | 11 | 25th August 2006 08:49 PM |
| Page generated in 0.07368 seconds (73.83% PHP - 26.17% MySQL) with 10 queries |
