wazzy said:i just bought 4 lm3886t's and not a single one worked. i used lm3886tf's in exactly the same boards and the ywork perfectly.
of course he did, he knows the difference between a T and a TF spec device.Did you electrically isolate them from the heatsink?
AndrewT said:of course he did, he knows the difference between a T and a TF spec device.
I am not certain, that he knows.
The only certainty in this respect from the information here was that my question was logical.
Thanks Samuel.
Seems that you're still smarting, Andrew. Good to see.
Stuey
i did not mean to open such a can of worms, sorry guys. i actually hadn't put them into a chassis yet, i have a heatsink that is mounted on a piece of mdf that i use for testing any new configurations that i may be trying out so as there is no chassis there is no chassis ground, thanks for your time tho. my supplier replaced the faulty ics so no worries! good service for africa!
No problems, Wazzy.
Once you do put it into a chassis, I find it easier to isolate the IC than the heatsink, even though it of course has an effect on the thermal performance of the chip.
I also prefer to have as much of the metal (ie. the heatsink) as possible connected to chassis ground and thus safety earth. But that's just a personal preference.
Good luck with your project.
Stu
Stu
not sure anyone cares..
but I work with National Semiconductor components on a daily basis, all across the range of items they produce..
the printing on the components is no indication whatsoever of whether they're real or fake.
I've seen three different writing finishes on the same component value/types!!
- Chip Amps
- Identifying fake LM3886
