Old 17th May 2009, 11:44 AM   #1
Default Problem with LM4780
Hello there!
Yesterday I did complete my PCB-board for a bridged LM4780.
Then I discovered a failure in my PCB. I had misunderstod how the mute-pin worked, and connected it to ground, so I removed the connection from those 2 pin, and soldered a 6K8 resistor to negative supply.
Today I have tested it, and it works, but there is a problem. When I turn it on, and play music, it doesn't play, but I have discovered, that it will work if I turn it on and off a few times.
Can it be wrong connection with the mute pin? and how many ohm should the resistor be at? I have a +/- 12.65 supply (25,3VDC).
Old 17th May 2009, 03:49 PM   #2
Okay, I can understand you can't help me without schematics, but I have used the schematics from the datasheets, and you can see my PCB-layout instead, but It's only singleside since I don't have acces to double layer.
LM4780 Bridged
Also I have experienced problems with oscillations and distortion in the higher freqencies, so I will apprechiate some help
Edit: The square vias on the pcb is jumpers, and they go verticals, and there are 4 jumpers.
And the pcb is also an edited one from my old, that had some mistakes
Simon H.A.
Old 17th May 2009, 05:25 PM   #3
connect your speakers leads to just one output of the dual channel chip and hear if it is playing.
Then try the other channel to test it.
If both appear to work, then come back.
regards Andrew T.
Old 17th May 2009, 05:27 PM   #4
They both work.
Old 17th May 2009, 05:34 PM   #5
Default Re: Problem with LM4780
They both work.
which?
regards Andrew T.
Old 17th May 2009, 05:37 PM   #6
Well, they both work, but maybe it's some of the protection applications in the chip that sometimes turn it off. It's totally cool and I'm loading it with 8 ohm, so I don't think I'm overlimiting it, but do you think my pcb is good enough?
And sometimes it oscillate, can I do more to prevent it?
Old 17th May 2009, 05:48 PM   #7
provide a link to the schematic you have used.
regards Andrew T.
Old 17th May 2009, 05:49 PM   #8
I have used bridged application in the datasheets, but I can see I have missed some of the components, so I will put them on the board and etche a new board and try again.
Datasheets
Simon H.A.
Old 17th May 2009, 07:11 PM   #9
bm0rg is offline bm0rg  United Kingdom
bm0rg's Avatar
Send a message via MSN to bm0rg
On page 18 of the cocument under LAYOUT, GROUND LOOPS AND STABILITY
consider using a star ground and have a look at the refrence board on page 22. I know its stereo but its a good refrence.
Old 17th May 2009, 08:09 PM   #10
Could it be that your supply voltage is too low?
12,65 V sounds like a 9 V transformer times 1,41 without considering mains fluctuation, voltage drop across rectifier diodes and voltage sag under load. Voltage sag will be an issue, if all you have are 470 µF per rail.
Measure the actual supply voltage, when it works and when it does not work. The IC switches off, when the negative rail has less then 9 V to ground and less than 14 V to the positive rail.
If you've always done it like that, then it's probably wrong. (Henry Ford)
LM4780 problem - need Help AndriyOL Chip Amps 56 29th January 2009 07:58 PM
Problem with LM4780 Dielkius Chip Amps 8 13th January 2007 01:06 PM
LM4780 problem Lamicz Chip Amps 6 6th November 2005 01:50 AM
LM4780 problem Faber Chip Amps 8 16th August 2004 04:39 PM
Page generated in 0.10356 seconds (83.98% PHP - 16.02% MySQL) with 10 queries
