| Chip Amps Amplifiers based on integrated circuits |
I'm considering building Peter Daniel's LM3875 Gainclone Kit to use with 8 ohm speakers. I live in Fiji that uses 240 volt mains. Are there any issues with using a Antek 400 VA with 20v dual secondaries toroidal transformer with this kit.
For example: 1) is 20 volt on the secondaries enough to gain optimum performance from this amp? 2) Would the 400 VA trannie require some sort of soft start circuitry etc? Or would I be better off buying a better quality transformer with 22 to 25 secondaries? Regards Glen |
#2 |
What is optimum performance for this amp? Depending on the capacitance in your power supply you can expect 30 W ±10 % into 8 Ohm. If that is fine for you depends on the speaker's effciency and your average listening volume.
The 400 VA transformer would probably be okay without, but it is nevertheless good to have a soft-start, because you may have other appliances connected to the same circuit and the inrush current combined with the other consumptions could lead to convenience tripping of the fuse/circuit-breaker for that circuit. A transformer of half the power rating would be enough even for two amplifier channels at 2x20 V. BTW, why is it called "convenience blowing", when it is really inconvenient, if it happens?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
what is the primary (mains) voltage of the Antek transformer?
regards Andrew T. |
#4 |
Anteks typically come with dual 115V primary windings.
#5 |
Thanks your comments and advise.
This Antek has dual 115v primaries. I intend to use Harbeth SHL5 speakers with the amp. I would rather use a trannie that will provide a bit more power output which may better suit these speakers. |
#6 |
a pair of 3875 will operate well with a transformer bewteen 120VA and 240VA. The only reason to select higher VA rating is to gain the advantage of the lower regulation available with bigger transformers. Anything bigger than 400VA is wasting money and space. What's the difference in regulation of 400VA and 500VA? Have you even asked?
regards Andrew T. |
| Full range driver recomendation for dual mono LM3875 gainclone? | zebra100 | Full Range | 5 | 4th August 2009 07:23 AM |
| LM3875 issues | Synesthesia | Chip Amps | 69 | 4th September 2008 07:04 AM |
| LM3875 Heat Sink Issues | cjv998 | Chip Amps | 16 | 23rd July 2007 09:21 AM |
| Dual Mono Gainclone Issues | cytokine | Chip Amps | 13 | 23rd November 2004 03:03 AM |
| FS: BrianGT gainclone kit. LM3875 Dual Mono Kit | mattjk | Swap Meet | 3 | 16th November 2004 12:24 AM |
| Page generated in 0.07898 seconds (76.59% PHP - 23.41% MySQL) with 10 queries |
