Why does this opamp hiss?
Old 7th May 2009, 10:57 PM   #1
cuibono is offline cuibono  United States
cuibono's Avatar
Default Why does this opamp hiss?
Sorry, noob question:
I'm working up an active filter circuit - in fact I've built it. It works as planned, but it has a noticeable amount of hiss. I'm'sure this is an EE101 question, but for better or worse, I never had EE101. Could someone point out the obvious?
By the way, the opamp are two quad packages, the TI TL054. I was hoping to share what this is for with the board, but it's not ready yet...
THANKS!
Old 8th May 2009, 01:19 AM   #2
infinia is offline infinia  United States
infinia's Avatar
Hi
Opamp voltage noise... the TL's are intended for instrumentmentation apps with a zener (noise source) trimmed for low offset voltage. The good part is your circuit uses low value resistors and low gains to minimize the current noise (only with low impedance input drive).
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 8th May 2009, 11:40 AM   #3
cuibono's Avatar
Thanks! The opamp's voltage noise was at the top of my list of suspects, but I was worried I had done something somewhere else I was unaware of.
But thats good - I only have to switch out the opamps! Much easier than having to redo the whole thing.
PF
Why does this opamp hiss?Hide this!Advertise here!
Hiss but no hum... RockysDad Tubes / Valves 13 5th April 2009 05:35 PM
Hiss in my P3a Amp blap0220 Solid State 15 1st June 2007 01:52 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
hiss jaudio Chip Amps 21 6th March 2005 05:02 PM
Help with Zen Headphone Amp - hiss... batee Headphone Systems 1 8th March 2004 07:14 AM
Copyright ©1999-2017 diyAudio
