Old 7th May 2009, 11:56 AM   #1
Post Audiophile Preamp
Hi All,
It's been a while since my last post, anyway i recently got back in the game and built a pretty good BPA with LM4780, i'm preparing another post dedicated to it with a lot of thanks for people in here, more on that later...
In order to drive the BPA I've built a few preamps using the TIs PGA23xx devices but i can't say i'm astonished with the results. They are quite good for their price and simplicity but i'm looking to build a true audiophile preamp.
I've been reading a lot of threads in the forum about preamps and although there is plenty of info i don't have a solid idea at the moment for an excellent preamp...
I'm particularly interested in attenuation methods.
Cost is not an issue, as i'm looking to achieve the best possible result.
I had the opportunity to listen to pre amps of the likes of Dartzeel, Burmester, Einstein and a few others... i'm not trying to get to that level.. but close.
I'll be very happy to hear your suggestions...
Old 7th May 2009, 01:28 PM   #2
klewis is offline klewis  United States
klewis's Avatar
have a look at this thread, not all the answers, but, some good recomendations.
National opamp inflation
Old 7th May 2009, 03:40 PM   #3
analog_sa's Avatar
Default Re: Audiophile Preamp
All the prepacked integrated solutions suck in various degrees. I have tried PGA2310, DS1666, DS1802. It is just frightening that manufacturers use these chips in pretty expensive equipment.
IME the best is a resistive attenuator with good switch and just two resistors per position. Which means either ladder or shunt attenuators. I usually choose shunt mostly for being a cheap-skate. A really nice series resistor and not so nice shunt resistors. 50% of the sound for 5% of the cost A Shallco, Seiden or at worst Elma switch.
Second best is using relays.
No experience with CMOS/Bipolar analogue switches controlling resistor dividers. Supposedly capable of very good results.
Also no experience with photoresistor based attenuators. Apparently good sounding, but high measurable distortion and extreme tweakiness repulse me.
TVCs did not work for me.
Getting the attenuator right is about 80% of a preamp. I guess the rest is 15% for PS and 5% for active circuit An amazing number of manufacturers get this completely wrong and fit a $5 volume control into a $5k preamp. Or they just know their typical customer all too well.
Old 7th May 2009, 04:11 PM   #4
Thanks for the replies,
klewis thanks for the link, i've used LME49710 and it is indeed impressive, maybe slightly better than AD797... not sure, they sound very similar.
analog_sa, i've considered the resistor array approach with relays (as i need it to be remote controlled) but my concern is switching noise on every step, both mechanical and electrical...
Anyone has done something similar?
I've been reading though this lightspeed attenuator thread... but i'm not convinced... i am considering to try it at some point.
Has anyone tried the resistor attenuator with silicon analog switches? such as the ADG series from Analog?
Any other ideas are welcome.
Old 7th May 2009, 06:07 PM   #5
analog_sa's Avatar
Not sure what you mean by resistor array. Most relay attenuators use very few resistors and some logic, usually following a binary sequence. This has the advantage of very few resistors (cheap), but multiple relay contacts and resistors along the signal for some positions. And of course some positions sound better than others.
Having experimented with relays i would generally prefer to avoid them or at least use as little as possible. I also noticed that the normally closed contact sounds much better than the energised one (magnetic field?). As a test i built a ten position attenuator using ten relays controlling ten shunt resistors. You need a simple logic circuit to make sure that the signal passes through a normally closed contact only and to provide output muting. This way you get a high quality attenuator which is also quite silent compared to attenuators where multiple relays switch at the same time. Of course you will need as many relays as attenuator positions you need and a simple controller which will probably also handle the remote functions. And probably a handful of relays to audition in order to avoid disappointment.
If anyone has information of the particular type CMOS switch BAT uses i promise to immediately order it and test.
Old 8th May 2009, 11:05 AM   #6
I guess this is the sort of thing you're talking about (attached).
Yes we're talking about the same thing, i just called it array because when you get high step count you need a lot of them.
I've tested a number of relays and i've found the Panasonic TXS to be quite good.
I'm considering doing some tests with the following alternative switching methods.
1. CMOS or dual supply silicon analog switches.
2. Photo MOS relays with Low CR
Problem is i don't have another attenuator to compare it with.
Old 8th May 2009, 11:16 AM   #7
Another scheme i'm thinking for 60 step attenuator.
This will work well for -60db to -10db, but as you get closer to the high levels you need another set of the bottom steps.
Again this follows the single signal path, no parallels.
Old 8th May 2009, 12:05 PM   #8
analog_sa's Avatar
3. Discrete bipolar transistor switches. Patented and used by Pass Labs.
I don't see the lack of an attenuator as a problem. A hard wired fixed resistor attenuator will provide a lovely comparison.
Old 8th May 2009, 01:35 PM   #9
Is there some schematic/example for the bipolar transistor method?
I've been looking around the forum but couldn't find them, neither on the Pass website.
Old 10th May 2009, 01:52 PM   #10
banana is offline banana  Hong Kong
Hi Otherside,
I'm using the shunt relay attentuator approach.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=107196&perpage=25&pagen umber=1
Just a little experience to share.
The close-time and open-time of a relay is not symetrical. It takes longer for a relay to move from open to close. In the case of shunt attentuator, there will be a moment that all relays are open, i.e. 0dB attentuation, or big pop! A time overlap is needed to remove this pop.
Also, the seemingly perfect isolation of relay still have about 6pF of contact capacitance. It's irrevevant for shunt attentuator, but will be a concern for channel switch.
About Non-Audiophile kin0kin Everything Else 55 21st March 2009 03:26 AM
Audiophile Preamp PCBs zargon1 Swap Meet 6 8th October 2008 07:43 PM
FS: Unfinished phono preamp w/ "audiophile" parts needtubes Swap Meet 1 5th July 2005 09:50 PM
Audiophile PC bjackson Digital Source 1 24th March 2005 07:01 AM
Page generated in 0.11720 seconds (82.38% PHP - 17.62% MySQL) with 11 queries
